Post by sToRm on Mar 2, 2019 21:14:06 GMT -5
Reuniting the collection. Bringing these two home from Philly this month. Elite 150D & 49cc Ruckus. My only GET engine Ruck. Stretched, airbox delete and front disc brakes. Camo box look familiar? Are you in PA? I live in Greensboro, NC now, but I will be in Philly in 3 weeks time. I left alot of stuff when I moved. Will be renting another U-Haul and driving back to Greensboro.
Post by Happypancake! on Mar 3, 2019 10:07:45 GMT -5
I live in Greensboro, NC now, but I will be in Philly in 3 weeks time. I left alot of stuff when I moved. Will be renting another U-Haul and driving back to Greensboro. Stop in at The Good Dog and eat a burger for me. I miss it !
Post by sToRm on Mar 3, 2019 14:14:44 GMT -5
Believe it or not this has already been modded by a top notch customizer. He used a 125cc Yamaha Zuma motor. I think it's for sale for $6000. This one is a Ruck with the Bite plastics and floorboard. Ruck guys don't sleep!
Post by aeroxbud on Mar 3, 2019 15:12:23 GMT -5
That blue one looks cool. Are the bits an Ruckus very similar then. It looks like it would be.
Post by fuzzyruttin on Mar 3, 2019 15:16:01 GMT -5
The Winter & Summer Collection.
Isn't the rear tire mounted backward on the green one?
Post by fuzzyruttin on Mar 3, 2019 15:18:07 GMT -5
That is one cool bite!
Post by sToRm on Mar 3, 2019 17:59:53 GMT -5
Isn't the rear tire mounted backward on the green one? Yes. When I got the wheels from MachineMachine, I didn't have tires for them right away. When I got the tires I dropped everything off at a tire fitting shop and told the guy to mount the tires so that the air valve is on the right hand side. And he did. Problem is, the rear wheel had the valve on the left hand side(not sure why). I only noticed it when I finally got around to mounting them. Haven't noticed any problems in the dry, so I will not be changing it until it wears out. I've seen people do this on the front but I'm probably the only fool that's running it on the rear.
Post by sToRm on Mar 3, 2019 18:02:52 GMT -5
That blue one looks cool. Are the bits an Ruckus very similar then. It looks like it would be. I think the front frames are the same. And it looks like Metropolitan wheels, triple tree and GET engine on the Bite.
Post by fuzzyruttin on Mar 3, 2019 18:14:01 GMT -5
Isn't the rear tire mounted backward on the green one? Yes. When I got the wheels from MachineMachine, I didn't have tires for them right away. When I got the tires I dropped everything off at a tire fitting shop and told the guy to mount the tires so that the air valve is on the right hand side. And he did. Problem is, the rear wheel had the valve on the left hand side(not sure why). I only noticed it when I finally got around to mounting them. Haven't noticed any problems in the dry, so I will not be changing it until it wears out. I've seen people do this on the front but I'm probably the only fool that's running it on the rear. I got machined machine wheels as well, valve on left. The valve has to be mounted in the depressed rib/groove (whatever it's called) otherwise it would interfere with tire mounting. At least I'm pretty sure that's the reasoning. When I received the wheels I was like, wtf, but I think that's why.
Post by sToRm on Mar 3, 2019 18:33:53 GMT -5
I think you're right. It confused me too because my 12x8 Douglas wheel has it on the right hand side. In fact, all my wheels had it on the right hand side, even the 12x7 golf cart wheels I used. This wheel was the only odd one out.
Post by sToRm on Apr 22, 2019 22:51:07 GMT -5
The Imperial Fleet. The journey to the dark side is now complete.
Post by spazter12 on Apr 23, 2019 8:06:31 GMT -5
Looking good 🤙🏼
dotdash
Post by dotdash on Apr 24, 2019 16:28:19 GMT -5
Gotta go get some tags with the black one. Do either have names? Both looking great. +++
Post by fuzzyruttin on Apr 24, 2019 18:06:13 GMT -5
Post by fuzzyruttin on Apr 24, 2019 18:07:32 GMT -5
Duck Rader
