Post by shordie on Aug 9, 2011 21:07:32 GMT -5
I found a hole in my gear oil case on the very bottom right near a small bolt but it does not look like a something broke it looks more like there may have been a plug there or something. Has anyone have an idea.............thanks
Post by ltsride on Aug 10, 2011 2:01:17 GMT -5
it is a vent hole, i have a 90cc with the same hole and for some reason it leaks. when i took it apart i could see it was like a mase and one of the gears slings oil up into a little hole then the oil travles through the mase and out the small hole you see at the bottom of the case an all over the side of the tire (not good) so i put a small plug in it.
Post by 2strokd on Aug 10, 2011 3:45:40 GMT -5
If its getting out the vent hole, you may have too much oil in it?
