shortman1166
Post by shortman1166 on Oct 26, 2018 2:41:51 GMT -5
I am wondering what a safe cold start RPM is for warm-up? I have my auto-enricher on a switch so I can leave it turned on longer in the winter to help warm up, but the motor runs at about 4000 until I hit the switch then it goes down to about 1700 rpm for normal idle after a minute or two. Is that a safe rpm for cold start and constant idle for about 3-5 minutes till the motor gets some heat built up and I ride it or should I lower it?
Post by geoffh on Oct 26, 2018 15:30:59 GMT -5
Short an,the enricher is at full on from cold the power supply gradually cuts off the extra fuel.I don't,t bother with a warm up just kick her up ride like you stole it.
shortman1166
Post by shortman1166 on Oct 26, 2018 15:43:13 GMT -5
Yes, I know how it works, I am just wondering if the 4k (cold) idle is too high for cold start to warm it up before I turn off the enricher(give it power)
Post by 90GTVert on Oct 26, 2018 16:10:11 GMT -5
That's pretty high, but as long as the scoot is secure so it won't takeoff if the wheel is spinning then it prob won't be a big issue. You could try adjusting the idle mixture again to see if you end up with less of a gap in the enricher on/off idle speeds.
Post by scooterpimp on Oct 26, 2018 18:20:00 GMT -5
I've noticed this behavior on stock carbs/jetting..hi enricher rpm. , after upjetting from stock (lean) jetting ive noticed a calmer/lower enricher engine speed. And it seems stock carbs need a twist or two on throttle for accelerator pump to prime/tickle prior to starting. Just my 2 cents worth. My zummer with 20 mm well/properly jetted carb. Can sit for days & fire up without priming & enricer speed is around 2200 rpm. Then settles to 1800 warmed up.
