xzdgx
Post by xzdgx on Aug 9, 2011 23:57:30 GMT -5
Hey guys,ive got very little money but i wanna make my scooter do a constant 50 mph all the time,Itll do 45 now almost all the time.Its a stock adly thunderbike 50cc all it has is a no rev cdi.I guess what im getting at is there any cheap way to get to 50mph.Or are there any little tweaks i can do to get there ?Thanks !
Post by reveeen on Aug 10, 2011 2:03:52 GMT -5
Post by 2strokd on Aug 10, 2011 3:44:39 GMT -5
Ide say vari too...Then pipe maybe? Of course vari being the cheaper.
Post by 90GTVert on Aug 10, 2011 6:57:12 GMT -5
You could check your squish and compression and see if it were possible to drop squish/raise compression a little for some kind of boost.
xzdgx
Post by xzdgx on Aug 10, 2011 13:35:30 GMT -5
okay thanks guys,now i need to go with a little lighter roller weight right ?prolly 5g ?and 12x15?
Post by stepthrutuner on Aug 10, 2011 17:55:18 GMT -5
If there were any way to know ahead of time the width of different drive belts I would suggest buying the brand that is the widest. Maybe someone has advice as to what brand that might be. That alone could net a 2-4 mph gain and would be the easiest mod. The gains would, of course, diminish as the belt wears. Placing an extra 0.5mm base gasket or two while removing the same or possibly an extra 0.25mm from the mating surface of the head could get your port durations up for higher revving. Finding a decent used performance (expansion chamber) for around fifty dollars is another easy option.
Post by 90GTVert on Aug 10, 2011 19:00:28 GMT -5
Gates makes a 788 18.1. I hate them because they kill takeoff so bad, but they're wide.
Post by stepthrutuner on Aug 10, 2011 19:26:33 GMT -5
Thanks, 90. I was hoping you might chime in on this.
xzdgx
Post by xzdgx on Aug 10, 2011 19:50:10 GMT -5
so between the wider belt,lighter vari weights and stiffer clutch spring i should be about 50?i just tuned my carb really well and that helps a lot.I just need a little more top end = )
Post by stepthrutuner on Aug 10, 2011 20:18:48 GMT -5
Lighter weights and/or stiffer contra spring is the opposite direction you want to go. Slightly lighter weights might not hurt the top speed or a little stiffer contra might not hurt either. Top speed will not go up though.
