Blow By
Aug 10, 2011 19:53:09 GMT -5
Post by dude on Aug 10, 2011 19:53:09 GMT -5
I am working on stock 49cc 4t. The comp. is 120psi should it be closer to 150psi? I havent checked the vavles. It has about 500 miles on it. But it has a lot of blow by coming out the vavle cover vent hose. Does not like to run with air box hooked up. I am thinking It maybe rings or crack piston. Almost forgot it was way over full on oil but not now. What do you think?
Blow By
Aug 10, 2011 20:09:40 GMT -5
Post by stepthrutuner on Aug 10, 2011 20:09:40 GMT -5
Not much you can do to improve that situation w/o cracking it open. Check/adjust the valves. If they need no adjustment you'll have to open it up and put in some new parts.... probably rings and head gasket at a minimum. Sounds like big bore time to me (not a lot more). If no money is desired to be spent on it use some Restore to get a few more hundred miles out of it.
Blow By
Aug 17, 2011 23:06:55 GMT -5
Post by dude on Aug 17, 2011 23:06:55 GMT -5
I tore it down and the 2nd ring was stuck. But because it was over full on oil does reverse hydrolock sound possible?
Almost forgot the 49cc had a 44mm bore/60cc
Blow By
Aug 18, 2011 6:58:57 GMT -5
Post by 90GTVert on Aug 18, 2011 6:58:57 GMT -5
I would think it'd take an awful lot of oil to hydolock it from the crank side. Most folks that add too much just end up pouring a full qt in. A full qt wouldn't lock the engine up I wouldn't think.
