Post by katt on Dec 26, 2018 21:29:05 GMT -5
Its safe to use Threadlocker Blue 242 in aluminum crankcase, how much to apply?
Post by gsx600racer on Dec 26, 2018 21:35:48 GMT -5
To seal the 2 case halves together or on the case bolt threads ?
Post by lilpinny on Dec 26, 2018 21:44:44 GMT -5
Heck ya...
Just a drop will do you.
Post by ryan_ott on Dec 26, 2018 21:45:49 GMT -5
242 is fine for threaded fasteners, I use just enough to cover the first few millimeters of threads and torque to spec.
Post by katt on Dec 26, 2018 22:08:01 GMT -5
To seal the 2 case halves together or on the case bolt threads ? Yeah and other misc bolts as well like engine mounts etc.
I just making sure its not to strong for aluminum.
Post by gsx600racer on Dec 26, 2018 22:40:46 GMT -5
To seal the 2 case halves together or on the case bolt threads ? Yeah and other misc bolts as well like engine mounts etc. I just making sure its not to strong for aluminum.
I suggest using Hondabond, Threebond, or Yamabond to seal the cases together.
Post by lilpinny on Dec 26, 2018 23:04:17 GMT -5
I use either blue or red on every bolt on my scoot.
Post by katt on Dec 27, 2018 0:16:11 GMT -5
I suggest using Hondabond, Threebond, or Yamabond to seal the cases together. Oh no i mean not wet gasket, but bolts.
thanks for the tip i need wet gasket as well.
Post by aeroxbud on Dec 27, 2018 6:10:12 GMT -5
Yamabond is pretty expensive here, as we only have one supplier in the U.K. Been using it for year's, and would never use anything else for cases. Something like assembling an engine just is not worth cutting corners.
Post by Lucass2T on Dec 27, 2018 8:23:22 GMT -5
Never heard nor seen anyone ever use threadlocker on crankcase bolts. Never used it myself on either one of the motors i have ever rebuilt in my life.
My first and foremost question is, why would you???
Post by jackrides on Dec 27, 2018 13:32:53 GMT -5
Red loctite is really serious stuff and may take extra tools and care to remove a fastener. Blue is good for most everything. The threaded hole must be clean of all substances. How do you tighten the screws?
Post by lilpinny on Dec 27, 2018 13:45:13 GMT -5
Red loctite is really serious stuff and may take extra tools and care to remove a fastener. Blue is good for most everything. The threaded hole must be clean of all substances. How do you tighten the screws? I got a 170cc GY6 on a honda ruckus. The thing shakes like crazy. Notorious for shaking themselves loose. I use red on the varilator nut, the clutch nut and the axle nuts. I have to use a torch to heat it up and an impact gun to loosen it. Then a brush to clean the threads off before I put it back on.
Post by katt on Dec 27, 2018 16:13:11 GMT -5
Never heard nor seen anyone ever use threadlocker on crankcase bolts. Never used it myself on either one of the motors i have ever rebuilt in my life. My first and foremost question is, why would you??? Well because it come with one originally i seen at the ends of the all crankcase bolts including ones that hold CVT cover white stuff (like oxidated theadlocker)
On and only one bolt out of crankcase come out without white stuff it had red thing like glue on it so i assume they used threadlocker on factory?
Post by lilpinny on Dec 27, 2018 16:43:10 GMT -5
On the 150cc GY6’s i’ve pulled apart, blue was used at the factory. There is the remanents of blue on every bolt I pulled out. The thing is you can’t really torque down on those Chinese aluminum cases since it’s a real low grade of aluminum... you’ll strip the threads right out of the case. They make up for it with a tiny drop of blue that’s lets you get it 1/8 turn past snug and locks it w/o too much torque.
Post by katt on Dec 27, 2018 17:24:58 GMT -5
I got this liquid gasket since this only brand that was available locally and i want finish this ASAP.
