bluebob71
Post by bluebob71 on Jan 1, 2019 14:22:16 GMT -5
been having a weird sticking issue on my scooter since i got it, seems the carb gets some gunk in it every 3 or 4 months. so during my cleaning i decided to see what the main jet was and once it was out there was no identifying numbers on it? would any one kno what the stock would be? ive seen them be all over like 100-110 ish
this is a walbro carb so i assume a decent carb?
bluebob71
Post by bluebob71 on Jan 2, 2019 11:29:23 GMT -5
if some one would kno the size that would help out as well, the main jet is bigger then any of my 50cc jets that i have.
Post by SMALL CC TEK on Jan 2, 2019 12:33:23 GMT -5
Should be a 110 main and a 35 pilot jet idle . But if you have done any serious mods exhaust pod filter you might go two points up on main again and see how it acts i have no idea of your elevation. Every motor is different but this is a base line or if it's a 125cc the main should be 108 . That gunk issue is only coming from one place your tank , clean it and install a automotive grade fuel filter and new lines i have seen rubber lines deteriorate inside and leave fragments in the carb.
Post by jackrides on Jan 2, 2019 14:47:43 GMT -5
A #60 - #80 drillbit set (micromark.com) serves nicely as jet gauges. Obviously use the dull end.
Post by SMALL CC TEK on Jan 2, 2019 17:56:07 GMT -5
A #60 - #80 drillbit set (micromark.com) serves nicely as jet gauges. Obviously use the dull end. That's a nice site i love that double ended pin vise ! LOL Right on . Thanks for the tip on that site something we all can use that site has a nice selection of small tools nice ...
bluebob71
Post by bluebob71 on Jan 3, 2019 1:10:49 GMT -5
Should be a 110 main and a 35 pilot jet idle . But if you have done any serious mods exhaust pod filter you might go two points up on main again and see how it acts i have no idea of your elevation. Every motor is different but this is a base line or if it's a 125cc the main should be 108 . That gunk issue is only coming from one place your tank , clean it and install a automotive grade fuel filter and new lines i have seen rubber lines deteriorate inside and leave fragments in the carb. how would it be coming from my tank? in my experience with any motorcycle it be airfilter. no mods done just a stock 150 some one drilled a center hole in the stock filter that i patched up recently this week so we will see if it fixes it. my gas tank is brand new and just installed so it shouldnt be that. just got a 2 gallon tank lol makes it a lot nicer for long trips. ive had a lot of 150s and never have had the same main jet in them ive had anything from 100 to a 115 in a stock 150, also would any one kno what size? these are bigger then the 50cc ones i have seen and thats all i seem to find on ebay. feel like im running a lil rich. also just found a small leak were the lil on/off valve thing is connect the tank to the petcock. im in michigan also so no elevation but i did notice when cleaning the carb the needle was all the way down so i moved it up 1 notch. appreciate all the info.
bluebob71
Post by bluebob71 on Jan 3, 2019 1:27:50 GMT -5
maybe my fuel filter is messed up idk.
bluebob71
Post by bluebob71 on Jan 3, 2019 1:34:05 GMT -5
if some one would kno the size that would help out as well, the main jet is bigger then any of my 50cc jets that i have. found the jets i needed.
Post by katt on Jan 15, 2019 3:00:26 GMT -5
been having a weird sticking issue on my scooter since i got it, seems the carb gets some gunk in it every 3 or 4 months. so during my cleaning i decided to see what the main jet was and once it was out there was no identifying numbers on it? would any one kno what the stock would be? ive seen them be all over like 100-110 ish this is a walbro carb so i assume a decent carb? I think its #100 or more i forgot.
bluebob71
Post by bluebob71 on Jan 30, 2019 10:53:46 GMT -5
well i found out its a air leak making me lean not the jet, either my carb needs rebuilt or my manifold needs to be replaced/gasket on it.
its been -30 with wind chill were i am so not doing shit lmao
