maccrew
Custom painted f-act
Post by maccrew on Aug 15, 2011 18:10:49 GMT -5
ok so my question is, my dum dum cousin never put oil in his scoot, its a 150cc air cooled cixi konced 150t-11, well after putting good oil in and using the scoot for a little while, it started to knock really bad, at least i think its a knock, btu i guess my question is where should we start? strip the motor top down and see if we can see the problem?
Post by Goosey on Aug 15, 2011 23:05:06 GMT -5
I'de start with the valves. If your lucky it's just a loose valve knock. Good luck with that one. No Oil?
maccrew
Post by maccrew on Aug 16, 2011 11:40:09 GMT -5
ya he ran the thing for a few weeks to a month or so, bone dry on oil, we put some in and then it started to have alot of issues with sluggish running and stalling out, now it has this knock and yesterday and driving it home from my grandpas where we took the cvt area apart to check that out, it wont even move now lol, starts just doesnt go.
Post by 90GTVert on Aug 16, 2011 12:29:24 GMT -5
Does it rev up and not move or just bog and not move?
maccrew
Post by maccrew on Aug 18, 2011 1:17:26 GMT -5
revs and doesnt move
Post by 90GTVert on Aug 18, 2011 6:39:40 GMT -5
The most common cause is a belt failure. Could be a clutch issue. Could be the variator nut has came loose or off, but there's usually a lot of noise associated with that.
Post by Goosey on Aug 18, 2011 9:24:59 GMT -5
Mhmm, check the CVT over again. Worked before but not after you were in there, something changed.
maccrew
Post by maccrew on Aug 18, 2011 12:35:02 GMT -5
well we had the cvt cover off to check that all out, it all checked out, i took the bell house and clutch out, them are fine, the variator the only prob is he has flat spots on his rollers, but other than the rollers, everything is fine, the knocking noise is coming motor side not tranny
Post by 90GTVert on Aug 18, 2011 13:30:42 GMT -5
Did you start it with the cover off? You should be able to see why it's not moving. Vari spinning? Clutch engaged? Will it spin the tire on the centerstand at least?
maccrew
Post by maccrew on Aug 18, 2011 21:06:34 GMT -5
ill check that out tomorrow when i remove the oil injection from his new 2t vento r3i turbocam
