Post by oldgeek on Jan 17, 2019 18:43:40 GMT -5
I have a design for a fairly simple template ready to be printed. Does anyone here have a 3D printer and the time to print something for me?
Perhaps there is a place you know of that can do it for me, cheaply? Thanks in advance!
Post by gsx600racer on Jan 17, 2019 20:50:14 GMT -5
I wish I could help ya. Iv been looking at them for awhile but there are other tools that are @ the front of the line.
Post by oldgeek on Jan 17, 2019 21:43:44 GMT -5
I wish I could help ya. Iv been looking at them for awhile but there are other tools that are @ the front of the line. Yeah they are pretty inexpensive around $200 for a reasonably rated entry level unit. I just dont feel like building a typical chinese KIT, and then there is the learning curve. I just can't invest the time needed to get up to speed on yet another technology. FreeCad was hard enough on the brain just to get the piece designed. Doing research on 3D printing, I saw where they can now produce metal parts and exotic material parts with special high$$ 3D printers. AMAZING!
Post by tsimi on Jan 17, 2019 21:56:38 GMT -5
pitobread has a CNC machine and 3D printer I think or at least he has access to one.
Post by oldgeek on Jan 17, 2019 22:08:21 GMT -5
Here is what I am trying to get printed. dimensions are 120mm x 120mm
Post by gsx600racer on Jan 17, 2019 23:57:47 GMT -5
Here is what I am trying to get printed. dimensions are 120mm x 120mm I am impressed with those self taught drawing skills. I had to go to school to learn 3D, but that was 20 years ago.
Post by oldgeek on Jan 18, 2019 7:21:17 GMT -5
Here is what I am trying to get printed. dimensions are 120mm x 120mm I am impressed with those self taught drawing skills. I had to go to school to learn 3D, but that was 20 years ago. Thanks. Pretty sure cad programs are easier to use now than they were 20 years ago. And I know they are easier to use than they were 30 years ago, because I had a copy of autocad and could not do anything with it! I used to open a drawing of the space shuttle that came with it and watch it load for 5 minutes.
Post by fuzzyruttin on Jan 18, 2019 11:51:13 GMT -5
Figured I would just go to my local library if that need ever presented itself. Might be fun just to play with it regardless. 3D printers
Post by FrankenMech on Jan 20, 2019 22:29:26 GMT -5
Check with some of the Maker Fairs around. They usually have exhibitors that will print designs.
andi
Scoot Newb
Post by andi on Apr 16, 2019 23:28:35 GMT -5
I haven't looked into the details in about a year, but I recall there was an open project where if you could get access to a 3d printer you could download the "blueprints" to print about %90 of the parts for a diy 3d printer with much larger print area then you'll get with a kit
Post by jeff84 on Apr 17, 2019 5:42:59 GMT -5
link I think emachineshop does 3d printing. im sure its pricey though. I looked into having a gear made for my final reduction, as there isn't much out there for my scooter. it was going to cost between 3-5 hundred depending on material, and chamfer options
Post by lordhater on Apr 17, 2019 8:25:37 GMT -5
Barrel base for a stroker? And if it is don't think that allthread is good enough for studs,,,it's not
Post by AtariGuy on Apr 24, 2019 12:39:08 GMT -5
Casting pattern perhaps. When you do find somebody with a 3d printer, you may want to show them the drawing as well and discuss the use. May help determine which filament lines to use, or if it may need a dual filament style for multiple materials. Theres also an option to include inserts - like if you have a steel/aluminum core, you guys would need locator points programmed in and set up a pause routine for when the core needs placement.
Keep asking questions, you'll be surprised what you learn!
Post by woodini on Apr 24, 2019 12:47:57 GMT -5
My coworker has two, im not sure how willing he would be to make parts tho. I know he made a replacement seat back tilter handle for another coworker of ours.... ill talk to him
Post by oldgeek on Apr 24, 2019 18:04:54 GMT -5
Barrel base for a stroker? And if it is don't think that allthread is good enough for studs,,,it's not Casting pattern perhaps. When you do find somebody with a 3d printer, you may want to show them the drawing as well and discuss the use. May help determine which filament lines to use, or if it may need a dual filament style for multiple materials. Theres also an option to include inserts - like if you have a steel/aluminum core, you guys would need locator points programmed in and set up a pause routine for when the core needs placement. Keep asking questions, you'll be surprised what you learn! Actually it is nothing more than a template to bolt to the cases. Then I will run a router using the template as a guide to open the cases up so larger bore cylinders will be able to slide into place.
