Post by pitobread on Feb 15, 2019 10:11:25 GMT -5
You guys pronounce 'Malossi' in such a weird way i have to make a comment aboooot it You pronounce the 'O' in Malossi as in road, coast, boat etc. But that O needs to be pronounced as in Ofcourse, Ordinary, Office etc. You're welcome I'm super Canadian, you should hear me say bar, far, car, dad, about.... the list goes on and on. Get a couple of drinks into me and I'm borderline indecipherable to the rest of the world.
Post by pitobread on Feb 15, 2019 10:16:02 GMT -5
Wonder if the ZX pulley is hitting my Stage6 bell in my Gyro, I've lost a lot of speed since changing from a stock clutch/bell on a ZX pulley and Alba variator to a Stage6 clutch and bell with Malosi spring. Most likely, you can run shims under the bell to space it out a bit depending on how much thread there is available for the nut. Next is to machine the lip off the pulley
Post by pitobread on Feb 15, 2019 10:41:33 GMT -5
I should also say that the backing support for the clutch pads can interfere with the pulley, you may need to grind it down.
Best way to check is assemble it without the spring and check range of movement
Post by pitobread on Feb 17, 2019 22:26:17 GMT -5
Here you go, free stuff!
Post by pitobread on Feb 24, 2019 0:00:32 GMT -5
Well I guess it's going to be a drag motor at this point.
Post by pitobread on Feb 25, 2019 0:59:13 GMT -5
Little more
Post by pitobread on Mar 11, 2019 14:23:06 GMT -5
Made the pipe up last night.
