Post by Fox on Aug 20, 2011 16:03:16 GMT -5
Prolly loose spade connectors on the coil. Remove the connectors from the coil and squeeze them a little with pliers so they grab onto the coil tightly. Loose ones cause stalling and/or erratic ignition. I doubt the orange coil will make a difference but hey, it's your money.
Post by sincitymopedryder on Aug 21, 2011 21:11:43 GMT -5
okay so my scooter started dying while riding again. bought a new coil and put it on thought was dying from that cuz its still all loose on top of the spark plug i do not know why the. the spark plug is tight the coil is brand new and its not snug at all it jiggles on top of the plug i got so pissed at my scooter i punched and broke the plastics ont he side. this morning opened and looked at the valves the exhaust valves was completely closed again could me having an exhaust leak cause this ?? ive put a gasket to fix that leak and make my scoot quite but it came loose and feel off while riding got another gasket and my headers came loose again and it fell off both times i used the red loctite i noticed my whole underseat airbox was really haggard and had holes in it broken spots a inch an half cut in the snorkel so i took it completly off took a ride with no air filter at all ran fine but lost alot of top end performance and i still cant find my electrical problem still nuthing but brake lights.
Post by 90GTVert on Aug 22, 2011 11:54:24 GMT -5
A leak at the header shouldn't cause the valves to tighten up. Any damage to the threads on the adjusters? Sure you got it tight last time?
