Post by magoconnor on Feb 27, 2019 17:00:39 GMT -5
Hello. How many hp should I expect with this setup? Everything will be dialed in on a dyno.
Derbi Sender 2018
Unlimited cdi 6 gears polini 19mm cp voca kevlar clutch voca hq racing crankshaft stage6 r/t reeds Polini Aluminium 80ccm kit Voca cross carbon racing 80cc Voca evo silencer Stock air box with high flow insert.
Cheers Mag.
Post by Lucass2T on Feb 27, 2019 17:04:36 GMT -5
A million
Post by tiny on Feb 27, 2019 18:09:37 GMT -5
I would hazard a guess of 3-5hp
Post by aeroxbud on Feb 27, 2019 18:26:54 GMT -5
The exhaust might restrict it some. It's quoted as "Making a peak power of 17.5 HP at 12300 RPM when used with the correct exhaust system 21mm or above carburettor." Probably 10-12hp then.
Post by aeroxbud on Feb 27, 2019 18:29:56 GMT -5
I would hazard a guess of 3-5hp You have been buying too many of those stock 60MPH Chinese scooters. It's made you jaded
Post by ThaiGyro on Mar 3, 2019 8:50:44 GMT -5
I agree with AeroxBud...shooting for 12 is a good goal. I am curious about your stated air-box insert. What is a "high flow insert"? Pictures? I do my own air boxes for 4T FI engines, but 2T air box mods are not easy to gain results. Keeping it though is smart.
Post by magoconnor on Mar 5, 2019 14:50:50 GMT -5
Update from the dyno: Hk = 15,1 at the wheel, with 13500 rpms Top speed = 86,99 mph It did pretty good I think Not blue printed or anything. I tried opening up the stock air box a bit. It gained a little top end, but the loss of torque in the bottom end, made it not worth it.
Post by 190mech on Mar 5, 2019 20:16:08 GMT -5
Looks good Dude!Wonder how many CC's it would take to get a 4 stroke in that HP class??
Post by ThaiGyro on Mar 8, 2019 12:02:02 GMT -5
