Post by scooternub on Feb 28, 2019 9:42:39 GMT -5
Edit: the tire model matches the one on the scooter. So when 2strokd pulled the exhaust from the engine when he changed the rear break pads on my scooter "adly hammerhead", the gasket from what I can tell was oval with two bolt holes, so I ordered an exhaust gasket and it's circular as seen in the picture. I ordered the gasket with the full tire set from ajusa.parts specifically www.ajusa.parts/scooter-parts/scooter-parts-silver-fox-50/silver-fox-50-exhaust Any thoughts? I am now afraid that the rims spline will not fit the scooters. If the link is wrong for my scooter as recommended the rims spline might not fit.
Post by ryan_ott on Feb 28, 2019 10:09:08 GMT -5
That is the original gasket type for many scoots. They seal well but I prefer the oval composite type gaskets. Either will work and shouldn’t affect the mounting position of the exhaust.
Post by aeroxbud on Feb 28, 2019 10:56:43 GMT -5
Post by scooternub on Mar 1, 2019 18:05:12 GMT -5
Post by aeroxbud on Mar 1, 2019 20:54:31 GMT -5
Post by scooternub on Mar 2, 2019 5:56:11 GMT -5
Post by geoffh on Mar 2, 2019 9:46:50 GMT -5
The slide in ones are my choice,I don't,t sleep unless I,ve got 2 spare and studs to match.
Post by scooternub on Mar 2, 2019 13:06:54 GMT -5
The slide in ones are my choice,I don't,t sleep unless I,ve got 2 spare and studs to match. Geoff This is what I dread, studs. Breaking one.
Post by geoffh on Mar 3, 2019 9:55:06 GMT -5
Studs braking,use wd40 let it soak in overnight,but it will happen,I,he tried all sorts to repair a barrel now I just order a cheap cast replacement to save time and skinned knuckles and curses.
Post by harleyracer59 on Mar 3, 2019 20:10:42 GMT -5
Mopedfactory on fleabay has stud, long acorn nuts and gasket kits for 2$ obo. I got 4 kits for a 1$ each. Might help Honda and gy6 peoples. They obo all three actions. And will haggle down pretty far. They might have your gaskets too if they’re different from my Honda dinosaurs. I get jets gaskets pistons from them. Delivered in about 2-3 weeks. Will ship faster if you hit them up. Just an option.
