Post by harleyracer59 on Mar 10, 2019 20:10:46 GMT -5
There is a guy in the philippines that can get you wheels and hubs. I got a set for my jog from him, very reputable guy. Yep there are a few people.. But they don't end up looking like monkey wheels when you are done, because the hub is like 50% of the wheel. with this you actually have mostly wheel face, instead of all hub. are your rims 8" or 10"? I got some 10"x2.75
Post by pitobread on Mar 10, 2019 21:36:09 GMT -5
10
Post by pitobread on Mar 10, 2019 21:36:45 GMT -5
there are drum monkey fonts..... rear tho....
Post by harleyracer59 on Mar 10, 2019 21:42:09 GMT -5
yeah but what size are the monkey front drums? on my blue aero rims im running that DIO drum hub with 95mm brakes and an elite 150ccfront drum hub with 110mm drum. huge upgrade from the stock 80mm these old Hondas steel wheels came with.
Post by 2smokeruck on Mar 11, 2019 0:15:28 GMT -5
I got these, theyre FSN wheels.
Post by pitobread on Mar 11, 2019 12:04:26 GMT -5
yeah but what size are the monkey front drums? on my blue aero rims im running that DIO drum hub with 95mm brakes and an elite 155 front drum hub with 110mm drum. huge upgrade from the stock 80mm these old Hondas steel wheels came with. Not sure.
Post by harleyracer59 on Mar 11, 2019 19:38:25 GMT -5
I got these, theyre FSN wheels. These are the “hibryd” rims pito is talking about. Monkey rims machined for a dio timer drum and if that front drum is 111max dis stamped in the inside, that’s a 150 elite or a copy of it. All polished out. I see what pito means by how huge these dio hubs are on the monkey rims. Interesting thing I notice is your front hub mounts backwards. On my rims, the tabs on hub/ drum are on the other side. Those are purdy wheels btw.
Post by pitobread on Mar 11, 2019 19:41:53 GMT -5
It depends on the wheel offset which side you mount it on.
His wheels are FSN, they are a wheel manufactured for scooters/dio's Not monkeys.
Post by harleyracer59 on Mar 11, 2019 19:52:08 GMT -5
It depends on the wheel offset which side you mount it on. His wheels are FSN, they are a wheel manufactured for scooters/dio's Not monkeys. really? I thought they were machined monkey rims because the hub tabs intrued on the styling holes
Post by 2smokeruck on Mar 11, 2019 23:28:20 GMT -5
Yea those were made for scooters with a 4x140 pattern i believe. The hub you see with the tabs out actually goes on the other side of the wheel. The guy i got them from is the only person i know of that ships to the US, trust me i've looked. Thanks btw, still undecided whether to put my kendas on them or get something else. Kendas are barely used though.
Post by pitobread on Mar 13, 2019 9:08:44 GMT -5
Monkey time.
Post by pitobread on Mar 14, 2019 5:14:22 GMT -5
Getting the frame setup for the wheels.
Post by 2smokeruck on Mar 17, 2019 23:03:28 GMT -5
So whats the rotor bolt pattern on dios? Looking for a rotor for my jog.
Post by pitobread on Mar 17, 2019 23:50:33 GMT -5
It Runs! Plus a lot of the little bits needed to get the wheels on it!
2smokeruck, I will measure both for you tomorrow.
Post by 2smokeruck on Mar 17, 2019 23:55:55 GMT -5
Awesome thanks pitobread!
