Post by pitobread on Mar 2, 2019 14:13:01 GMT -5
Another Dio Build, this one is not mine, I swear, I am just building it for a friend....
TWH Mini Stroke cylinder CMR Mini Stroke crank TWH Intake Polini 23 TFC Vario kit New Plastics! New Wheels! Lots of JDM goodies
Right now its a pile on my floor.
Post by harleyracer59 on Mar 2, 2019 16:32:43 GMT -5
damn. I wish I had a mill... lol should be a cool build.
Post by pitobread on Mar 3, 2019 22:52:15 GMT -5
Motor kinda assembled...
Ran into some CMR issues, it would rub the cases .. so last minute swap to the Taida Crank.
Post by pitobread on Mar 4, 2019 2:33:05 GMT -5
Motor Assembled.
Post by pitobread on Mar 8, 2019 10:27:38 GMT -5
Relevant to this build, making a monkey bike wheel rear hub from another old wheel.
Post by benji on Mar 8, 2019 15:56:39 GMT -5
How come you didn't use a Kymco hub?
Post by pitobread on Mar 8, 2019 16:43:08 GMT -5
How come you didn't use a Kymco hub? I have done that before. You have to bore out the wheel to fit monkey wheels or get dio specific wheels. The didi17 hubs are 4x137 This let's you bolt a monkey wheel directly.
Post by benji on Mar 9, 2019 10:00:13 GMT -5
What pattern are the monkey wheels? I would think just making an adapter would be less work and cost less than machining out a dio wheel. But I don't have a lathe or mill either
Post by pitobread on Mar 9, 2019 11:17:17 GMT -5
4x90 Didi is 4x137
You can make an adapter, but the space before the wheel hits the exhaust mount is already very small.
Short of buying an adapter this is the best way to do this. Plus this will be used on a 3.5J rim so it's already going to be tight.
Post by harleyracer59 on Mar 10, 2019 13:10:15 GMT -5
I cant believe there is a 47mm difference in bolt patterns. I bought a set of monkey wheels a couple months ago. slow boat should be in usa. rims should be here in a week or so. I gotta figure out a front drum hub, and now make a rear hub?? dhooo
Post by 2smokeruck on Mar 10, 2019 16:35:35 GMT -5
There is a guy in the philippines that can get you wheels and hubs. I got a set for my jog from him, very reputable guy.
Post by benji on Mar 10, 2019 16:36:30 GMT -5
There is a guy in the philippines that can get you wheels and hubs. I got a set for my jog from him, very reputable guy. name please. Very interested.
Post by 2smokeruck on Mar 10, 2019 16:48:35 GMT -5
Richmon De Jesus on facebook messenger. He restores them with all new hardware and polishes them.
Post by pitobread on Mar 10, 2019 17:35:47 GMT -5
I cant believe there is a 47mm difference in bolt patterns. I bought a set of monkey wheels a couple months ago. slow boat should be in usa. rims should be here in a week or so. I gotta figure out a front drum hub, and now make a rear hub?? dhooo I mean you could take some steelies and weld some adapter rings on to them then get them turned true and redrill
Post by pitobread on Mar 10, 2019 17:36:58 GMT -5
There is a guy in the philippines that can get you wheels and hubs. I got a set for my jog from him, very reputable guy. Yep there are a few people.. But they don't end up looking like monkey wheels when you are done, because the hub is like 50% of the wheel. with this you actually have mostly wheel face, instead of all hub.
