Post by darius823 on Apr 23, 2019 12:15:49 GMT -5
I saw couple cylinder head sensors are they any good and do you recomend any of them
Post by 90GTVert on Apr 24, 2019 7:48:26 GMT -5
Cylinder head temperature (CHT) gauges can be a good tool for tuning and to help you see when something is going wrong. The easy way to do it is an under plug sender. It goes over the threads of the plug and sits between the plug and head. Make sure you get the right sensor size for your plug, which should be 10mm if you have a 139QMB. Trail Tech is a popular brand and you can get a full gauge solution like the Vapor or just a CHT gauge like the TTO. There are definitely cheaper options, but I've had pretty good luck with Trail Tech and they do offer some support. One negative to the TTO is that you can't change the battery, but I've had some of my TTOs for more than 5 years and they're still working. Here's a TTO with 10mm plug sensor (if you use an NGK the plug number will start with a C like CR7HIX) : amzn.to/2Dym13sYou will probably also need an extension so the sensor reaches the gauge with those. Here's a 72", but you cna get them shorter : www.trailtech.net/v300-72
