Post by KSR Moto on May 3, 2019 14:08:54 GMT -5
What is the difference between those two plus if there is any, they look the same too
Rune 75
Post by Rune 75 on May 3, 2019 15:07:28 GMT -5
The A means what type of firing end construction the sparkplug has. According to NGK A and B = special design. That's all the information NGK gives.
Post by SMALL CC TEK on May 3, 2019 23:24:22 GMT -5
What is the difference between those two plus if there is any, they look the same too C 10mm R Resistor 7 heat range H Length of plug S nickel non v A special design Any bike with a computer or electronic ecu or radio you should have a resistor plug even your intercom system can be effected without a resistor plug .
