letsgobows20
Scoot Newb
"I went to the store to buy candle holders, but they were sold out. I bought a cake instead"
Post by letsgobows20 on Aug 26, 2011 4:01:16 GMT -5
i have a 2005 vento triton r4 moped. the two bolts that mounts to the exhaust pipe hangers fell off. the bolts were about bigger than 3 in. if anyone owns this moped, please let me know what the thread pitch is
Post by 90GTVert on Aug 26, 2011 6:38:47 GMT -5
:welcome:
I wanna say they're M8x1.25, but I'm not sure on that. It's been a while since I've used that style of muffler.
letsgobows20
Scoot Newb
Post by letsgobows20 on Aug 29, 2011 3:07:38 GMT -5
you were right..thanks!
Post by zumasterling on Sept 17, 2011 12:25:54 GMT -5
If you ride in an area with rough roads or in a city then these ventos have a tendency to break the exhaust brackets and the pipe bands. I have taken to strengthening the bracket itself with a peice of flat bar with two holes in it, one that bolts where the top bracket bolts in and drilling a hole into the bracket between the two exhaust band mounts and bolt the flat bar with a bolt and locking nut as well as replacing the exhaust bands with motorcycle pipe bands as a preventative measure. The two exhaust band mounts also have a tendency to break at the welds and either need to be rewelded or you can reuse the mounts and get longer bolts that will go through them and allow you to put another piece of flat bar behind the mounts and a locking nut on the longer bolts on the other side of the flat bar.
