Post by houseoffubar on Jul 14, 2019 1:00:00 GMT -5
Hello, I bought a new motor from OfferUp and I’m building a little hotrod motor out of it, but I don’t know how to tell what stator I have. How do I tell if it is and AC or DC unit? Thanks!
Post by oakleyscoot on Jul 14, 2019 8:58:57 GMT -5
Any stator will only be AC. DC only occurs when the AC from the stator is rectified.
Post by snaker on Jul 14, 2019 12:01:12 GMT -5
Like oakleyscoot says, magneto stators only output AC, both lighting coil and ignition coil. The stator styles (AC or DC)refer to the available ignition power.
A AC style stator will have the odd ball paper covered pole/s that generate ac ignition power. It includes a ac lighting coil output circuit and a ac ignition power coil circuit.
A DC style stator will not have the oddball poles for ignition power. It is called a DC style by default since it doesn't offer ac ignition power and the machine would get ignition power from the dc battery. It only outputs ac lighting coil power.
Post by houseoffubar on Jul 18, 2019 4:00:07 GMT -5
Thanks Guys! I guess I should have known the Stator is AC. My issue, to be more clear, is trying to find the correct Regulator. I have not found one with the right plug to match the plug coming from my stator. That said, I can probably change the plug to adapt it to the regulator I have, provided it is an AC or DC output unit?
Post by houseoffubar on Jul 18, 2019 16:53:27 GMT -5
Like oakleyscoot says, magneto stators only output AC, both lighting coil and ignition coil. The stator styles (AC or DC)refer to the available ignition power. A AC style stator will have the odd ball paper covered pole/s that generate ac ignition power. It includes a ac lighting coil output circuit and a ac ignition power coil circuit. A DC style stator will not have the oddball poles for ignition power. It is called a DC style by default since it doesn't offer ac ignition power and the machine would get ignition power from the dc battery. It only outputs ac lighting coil power. Looks like the AC style, I will proceed as such😊
Post by houseoffubar on Jul 18, 2019 18:38:13 GMT -5
So here is the thing I can’t figure out. My stator has the oddball coil wrapped in tape, so for an AC type!? However instead of having three yellow wires out of it, there is a white, yellow and green wire, as well as a plug that does not seem to fit the regulators I have found. Any suggestions?
Post by SMALL CC TEK on Jul 18, 2019 21:56:30 GMT -5
Got a pic of the stator and plug ?
Post by houseoffubar on Jul 19, 2019 0:01:35 GMT -5
I do, but don’t know how to attach them here
Post by 190mech on Jul 19, 2019 3:59:22 GMT -5
Post by snaker on Jul 19, 2019 12:08:09 GMT -5
Single phase full wave
Three phase
The three general types of magneto stator on Gy6 engines
Single phase half wave
Post by snaker on Jul 19, 2019 12:23:22 GMT -5
Sorry I got the diagrams mixed up. I have more trouble with this proboards system locking up and moving stuff than anything else.
Put your attention on the stators. Your description points to a single phase stator. Can't tell if it is half wave or full wave just by looking, you have to use a meter and check for continuity between ground and the yel and wht. If there is low resistance then you have half wave. If open then you have full wave.
Stator and rr have to match.
