Post by bluesi808 on Sept 1, 2011 0:12:25 GMT -5
Is there a huge difference in performance between a 17.5mm Dellorto and a 19mm or even a 21mm? Also im keeping the stock air box and i'm getting a 70cc polini sport on a 140qmb keeway matrix.
Post by reveeen on Sept 1, 2011 5:04:33 GMT -5
You are kinda asking: how high is up?
Your engine is an air pump. You should be *thinking*: "how can I maximize air flow through this thing?
So your question: Is there a huge difference in performance between a 17.5mm Dellorto and a 19mm or even a 21mm?
Is hard to answer. On a stock, RPM limited, engine: no there is no "big" difference. Add a 70cc kit: the difference grows Port, and case match, that kit: it get's bigger Add an exhaust: bigger still Add a larger intake, reed block: bigger
Typically, on a 70cc, with an exhaust, 19mm seems to be "the choice", the 17.5 will work, be a bit easier to tune, but gives you no growing room.
Post by 90GTVert on Sept 1, 2011 5:10:18 GMT -5
For a sport kit you probably won't see much, if any, difference in performance of the 3. In theory you should see gas mileage decrease as venturi size increases, but I doubt that will be a major difference between those three either. The 19-21mm should be sufficient for any future setups within reason, that would be a big reason for me to go larger. I use a 21mm on my 96cc and 2strokd even uses a 21mm on the infamous 103cc Skeedr drag scoot.
Post by reveeen on Sept 1, 2011 13:13:23 GMT -5
I have some 24mm "stupidity" going on here..... when really, all that is needed, is 20mm.
(I'm having to use the big stuff to match up with the reed blocks/manifolds)
