Post by stancejontland on Jul 16, 2019 22:33:02 GMT -5
Whats up guys. Ever since i have had my scoot the right side mirror hole and surrounding area have been broken. Ive tried gluing and tape but it keeps breaking. Wondering what i could do. Maybe cut it? Find a similar body panel to fit? Its a baccio vx50. Ill post a picture below
Post by kj4spj on Jul 17, 2019 12:09:06 GMT -5
cut you a piece of wire mesh to the desired shape and size and just heat it up and weld it back into shape you have all the pieces get a plastic welder and heat the wire mesh on the back side and then you could use a little Bondo to fill into tiny cracks. he'll be just as strong as the original. I shot some video on how to plastic weld it's not the best video but it gives you the gist of it
PDub
Ann Arbor MEEEEEchigan
Post by PDub on Jul 19, 2019 10:38:16 GMT -5
You could also use epoxy: cut a thin piece of sheet aluminum to fit behind it & epoxy it on with plenty of little clamps. Then Bondo on the front with sanding/painting after. I would cut the aluminum piece to extend pretty far into unbroken plastic in both directions, and gently form it to the shape of the cowling before gluing.
