Post by sincitymopedryder on Sept 9, 2011 10:45:32 GMT -5
okay so after like an hour of riding ill die while riding which realy sux when you have no blinkers lol but when i pull over i see that my fuel filter is onle one fourth full i pull off the vaccum line off the intake manifold and suck on it and fuel slowly fills back up in the fule filter and it starts right up and goes for like 20 mins before doing it again. any ideas?
Post by ososlow on Sept 9, 2011 11:46:13 GMT -5
i had a buddy 50 for a couple of weeks that was doing the same thing. i never figured out what it was before i got the VIP and started to strip the buddy for parts. i can however tell you that i checked the vacuum line for leaks, made sure the the im gasket wasn't leaking, and checked the valve clearances with no luck. my next step would have been to try to clean out the petcock and if that didn't work i would have tried replacing it.
Post by Fox on Sept 9, 2011 14:39:19 GMT -5
Could be debris in the fuel valve, or a cracked vacuum line/leak. Is there a fuel filter between the tank and the valve? If not there should be. Lots of scooters have the filter attached between the valve and the carb. so tank rust can get into the valve and cause problems.
Post by jmkjr72 on Sept 9, 2011 22:24:37 GMT -5
check your tank vent to see if its cloged or just drill a small hole in the gas cap or insead of pulling every thing apart remove the gas cap and see if it works again i know the buddy 125 and 150 had issues with vapor lock
Post by Fox on Sept 9, 2011 22:58:29 GMT -5
Good point^^^
If the tank vent stops up then fuel can't flow out of it fast enough to feed the engine.
