Post by ravensguildassasin on Sept 10, 2011 14:36:17 GMT -5
ok so i got my new 150cc lb150t-12 adventure scooter named you guessed it DoomBringer. now the blinker is fixed bought a new flasher relay from autozone. i will take pics and such on the scooter later but i have to work the next few days.
Post by 90GTVert on Sept 10, 2011 16:55:34 GMT -5
Congrats!
Post by ravensguildassasin on Sept 10, 2011 23:23:02 GMT -5
so this scooter is so much faster. i have had it up to 90 kph so far. but that was in town so i got scared and slowed back down to 50 kph. its fun to ride though i love it so much more then the last one.
Post by ravensguildassasin on Sept 11, 2011 12:32:58 GMT -5
Post by ravensguildassasin on Sept 12, 2011 13:53:20 GMT -5
well changed the oil i have seen cars that have gone a year before an oil change with cleaner looking oil. ran some chemical cleaner through it and change the oil again. now it seems to run better. not that it ran badly before. i will be making a trip to my mom and dads soon on it. it is only a hundred miles or so but i wanted to do it for a bit. just could not bring myself to do it on the 50cc.
Post by 90GTVert on Sept 12, 2011 15:08:47 GMT -5
Kudos on the thorough oil change. If you didn't already, clean the screen out next time around too.
Good luck on your trip.
Post by ososlow on Sept 12, 2011 17:14:32 GMT -5
hmm... cant see your pics. or your avatar for some reason
Post by 90GTVert on Sept 12, 2011 19:16:24 GMT -5
They all work for me.
Post by ravensguildassasin on Sept 12, 2011 23:50:52 GMT -5
yeah the screen was surprisingly clean. had a bit of a scare on the way home from work tonight the lights just died. well hit a bump and they came back on. so i thought ok its just a short checked some wires taped them up along with the connections now its all fixed. but damn its scary as hell going down hill at 45~50 mph and all of the sudden no lights.
Post by ososlow on Sept 13, 2011 8:49:39 GMT -5
they work on this computer. nice scoot. i almost just bought a yellow one of those. i think it was called something different though
Post by ravensguildassasin on Sept 13, 2011 22:18:48 GMT -5
ok so odd issue running to my rents no problem 60 mph all the way there. was there for a few hours on the way home it would bog down randomly. now idk if this makes a difference or not but it was 80 when i went out there and 65 when i came home. i have no idea what it could be, but the scooter is all stock.
Post by 90GTVert on Sept 14, 2011 5:35:37 GMT -5
Was it really completely random, any speed/any throttle position, or did it happen only at WOT cruising or only when accelerating for example? If it's completely random the first thing I usually do is check for anything loose in the ignition system or loose hoses or other carb connections.
Post by ravensguildassasin on Sept 14, 2011 11:44:40 GMT -5
sorry intermittent at wot i think would be a better description of it. it was around 55+ mph when it did it but not all the time just intermittently i think it happened three times all on flats.
Post by 90GTVert on Sept 14, 2011 12:12:02 GMT -5
If you just let off and then got back into it and it was OK it could be a lean or rich condition. A look at the plug might help you decide which is most likely.
Post by ravensguildassasin on Sept 16, 2011 17:25:10 GMT -5
you know i see all these things for an intake manifold for the 150cc.... but why not just flip the manifold and carburetor around? would that not be easier then having a pos tube on the manifold. another note this is a custom exhaust idea of mine. input welcomed. and yes yes my skills at paint are unmatched i know.
