Post by ososlow on Sept 19, 2011 16:14:56 GMT -5
forgive my ignorance but.... what is that suppose to do??
Post by ravensguildassasin on Sept 19, 2011 23:09:32 GMT -5
its like baffle plates in a flowmaster it helps keep the noise down. in theory
Post by 90GTVert on Sept 20, 2011 0:40:00 GMT -5
I like the exhaust idea. The chambered muffler I built for a friend's 150 sounded beefy. Deepest sound I've heard outta one. Unfortunately vids do it no justice, but there's one below anyway. The only problem with it was the square look. I made it just like a little 2 chamber muffler. Something similar in cylindrical form would be sweet!
Post by 2strokd on Sept 20, 2011 7:24:54 GMT -5
That homemade "Vertchamber" muffler is still my favorite! You ever see the prices of the fourpoke exhausts? Holy WOW! I thought our 2T pipe were bad! They want just as much for a plain ole nuthin fancy exhaust for a four. Make more of those and i bet you could make some money!?!
Post by 2strokd on Sept 20, 2011 7:26:01 GMT -5
Back to the topic... dont think the cones are beneficial at all in a fourstroke are they?
Post by 90GTVert on Sept 20, 2011 7:34:13 GMT -5
I think the cones are more about keeping exhaust out of corners, not really acting as a diffuser and convergent cone. My square muffler used metal sheets to triangle off the corners too. Here's what mine was like inside. Just so it's not totally confusing, the center piece is not as tall as the muffler, so it wasn't actually blocking off the exhaust, just acting as a vent.
Post by ravensguildassasin on Sept 20, 2011 16:19:06 GMT -5
yeah the idea on mine with the cones is to keep the flow going a single direction as to not create to much back pressure. ( in theory ) and i say in theory because i have yet to build one so i am not for sure on this yet. but i want it to be a round muffler.
Post by ravensguildassasin on Sept 27, 2011 21:58:32 GMT -5
:doh: ok away from the future and onto the now. Now i have an oil leak maybe from day one of me getting the scooter. (most likely the case) i cant seems to track it down and i need a new dip stick as the old one disintegrated when i went to check the oil. :facepalm: :doh:
Post by Fox on Sept 27, 2011 22:50:28 GMT -5
The bogging at WOT could be as simple as a fuel supply issue. Like a partially clogged fuel filter or a piece of debris in the petcock or something so the engine burns the gas slightly faster than it's supplied.
Post by ravensguildassasin on Sept 28, 2011 0:58:33 GMT -5
yeah i need to change the lines and fuel filter and such but it has to wait till the fifth.
Post by ravensguildassasin on Oct 3, 2011 13:37:20 GMT -5
ok im ordering a new set of sliders a belt and if i see anything else ill change it as well. i will be picking up a new plug fuel filter and such as well local.
:edit: it helps to mention that im going with a set of 10g sliders over what i hope i have is 14g rollers will find out Wednesday.
