Post by motorhead on Sept 13, 2011 10:58:09 GMT -5
I have always wondered if there was a specific measurable increase or decrease when you move the position of the e clip on carb needles. For example if you are in stock position with the clip in the middle and you move the clip to the bottom would that be like going up 5 sizes jetwise or should I look at it as you getting all you can from the jet you have in there?
Post by 90GTVert on Sept 13, 2011 11:47:03 GMT -5
From my experience, it can have a large effect on the midrange that maybe someone could equate to a jet size change, but it has only a minor effect on WOT that probably wouldn't be a jet size.
Post by reveeen on Sept 13, 2011 14:47:10 GMT -5
Needle position only affects the mixture from about 1/4 to 3/4 throttle.
Post by moore716 on Sept 18, 2011 13:25:50 GMT -5
^^^^^this right here^^^^^ it does slightly overlap the main and pilot jets though.
