Post by therellik on Oct 9, 2019 17:10:15 GMT -5
anyone did any? if so what did you use? im looking to switch to the LED light so I can see better at night. I cant see crap with this stock bulb. 3 feet on dim 6 feet on highs. I had to adjust the headlight to where the light would hit the ground to where I could see the road and still driving with my highs on.
Post by chehystpewpur on Oct 10, 2019 13:56:15 GMT -5
Post by chehystpewpur on Oct 10, 2019 13:58:51 GMT -5
drive.google.com/drive/folders/0By2rcNqfITkKdlYxWWY2Wm5nZ0k i had these before they were about 30-35 bux and were pretty slick too. 8 watt low beam and about 17 watt high beam. a little more wiring but had a nice demon eye and halos. not as bright as the projectors i retrofitted but very easy to install and did the job till the ballast died.
