Post by christopher on Oct 27, 2019 14:02:55 GMT -5
Post by 190mech on Oct 27, 2019 16:21:20 GMT -5
BWS 100 TD,will fit the smaller Mina Clones,been tried here a few times with OK results..
Post by Zino on Oct 27, 2019 16:22:25 GMT -5
Post by ryan_ott on Oct 27, 2019 16:51:15 GMT -5
I will add, I did get one of the Ali 122mm pulleys and the movement was pretty gritty. The slots were pretty large for the pins. As with everything from China no 2 are the same so the next one could of been great but something to consider. Short answer yes it will fit.
Post by christopher on Oct 27, 2019 17:20:44 GMT -5
Interesting to know, I don’t have a over range variator so I’m not sure how much of the 122 I would use. My front pulley is a 97mm Malossi multivar. I did see a few larger versions available but I want to keep my electric start. I bet the low end take off would be good. Wonder if it would still get to 35 on the top end? Guessing
Post by ryan_ott on Oct 27, 2019 18:01:41 GMT -5
The Polini hi speed variator I’m using isn’t anything special, as long as you get a belt to take advantage of the larger diameter you’ll see gains.
Post by christopher on Oct 27, 2019 18:15:38 GMT -5
The Polini hi speed variator I’m using isn’t anything special, as long as you get a belt to take advantage of the larger diameter you’ll see gains. What is the outer diameter of the Polini? Did you have to remove the electric start?
Post by Zino on Oct 27, 2019 18:59:41 GMT -5
polini high speed is 95 mm and is a non overrange variator you do not remove the starter I have both polini and malossi variators they are very simlira performnace wise I give the tiebreaker to the malossi
love2ride1111
Post by love2ride1111 on Oct 30, 2019 23:00:33 GMT -5
I was gonna say, I used to think buying things from Aliexpress or whatever they call themselves these days was good deals. Well I bought a "performance torque driver pulley" it took 6 weeks to show up and it caused more problems and nightmares then I care to go over.
