Post by milly on Oct 28, 2019 13:04:39 GMT -5
Recently on Violet ( LML Star / Stella 150 2T ) had a lot of smoke on start up if scooter stood a while. 2T oil in tank also started dropping. No 2T oil going in gear box but obvious it must be combustion chamber. To rememdy this I done a few things suggested like renew ball valve, spring and plastic blob that holds it in, changed all gaskets on carb, carb box and base of reed valve block where 2 pinions are and never fill oil to top, Been off it for a week. Starts up fine but boy does it smoke.
Now I could faff about with trying all stuff again or just put non autolube carb box, carb and fuel tank and remove all the gubbins from round behind clutch that powered the autolube. My only concern would be getting the jetting right as presume increase need and I hear on over run its possible to seize unless you blip the throttle. I dont know if that correct. The other option is to get rid of the evil 2T and get a nice little sedate 4T with emmissions controls on.
No that is not mist but 2t after a spin up the track
At tickover and when turned off
Post by oldgeek on Oct 28, 2019 13:11:30 GMT -5
Sell the stinky, noisy, smoking thing and ride the Django.
Post by milly on Oct 28, 2019 13:22:41 GMT -5
😃 oldgeek the Django gives me a sore bum and hurts my back after 50 miles. Its the most uncomfortable scooter or bike I have ridden in four or five decades any distance. Violet having a flat seat is very comfortable.
Post by geoffh on Oct 28, 2019 16:11:51 GMT -5
Just take the oil out,disconnect at carb plug it,go pre mix leave the Gubbins as is,pre mix is adoddle after two or three fill ups you may be able to use those mirrors.
Post by aeroxbud on Oct 28, 2019 16:15:33 GMT -5
It should not be that hard to sort the jetting out. If your going 2% premix, just go 2% up on the main jet.
Post by milly on Oct 28, 2019 17:59:14 GMT -5
Post by christopher on Oct 28, 2019 19:47:49 GMT -5
Fogging for mosquitoes? How about a vacuum operated valve like a fuel valve? I have a 4 stroke motorcycle also. I'm afraid I won't put in oil one day, since I don't have to on the larger motorcycle.
Post by milly on Nov 4, 2019 13:47:18 GMT -5
Pre mix it is! Ordered non autolube fuel tank same with carb and carb box and plugs to fill holes left behind might as well remove all the autolube gubbin's including bits behind clutch. Already got a non autolube reed valve block bought by mistake yonks ago and a new petrol tap. No going back now 😊 onwards!
Post by aeroxbud on Nov 4, 2019 15:27:48 GMT -5
No more smoke screen!
Post by christopher on Nov 4, 2019 19:35:56 GMT -5
Is this scooter one that is made in the old Vespa factory?
Post by harleyracer59 on Nov 4, 2019 20:43:21 GMT -5
while im a fan of the auto lube... if youre going premix id clean out the oil tank, put a valve and "T" it into the fuel line for extra fuel capacity.
Post by Zino on Nov 4, 2019 20:49:09 GMT -5
while im a fan of the auto lube... if youre going premix id clean out the oil tank, put a valve and "T" it into the fuel line for extra fuel capacity. N Now That is a great Idea like a reserve fuel tank .
Post by milly on Dec 10, 2019 5:16:43 GMT -5
Change over all done recently and running great
lupo76
Post by lupo76 on Dec 10, 2019 7:58:37 GMT -5
Mostly all Peugeot 2T with autolube do the same...
Why it´s a problem? First 2 minutes it´s more smoke than normal. Just ride it mate....
Post by benji on Dec 10, 2019 8:40:33 GMT -5
The jetting change depends on what mixture your gonna use premix-wise. If you do a low ratio like 50:1 then you'll probably match the OEM autolube output and not need much of a jetting change. Also, 'blipping' the throttle on downhills is always a good idea on a 2t since the fuel is where the oil is, either premix or autolube. Giving it a quick little rev throws more lubricating oil on the cylinder and cooling gasoline on the piston, as most of the time your throttle is closed down hill restricting how much fuel/oil it gets.
