Post by aeroxbud on Nov 7, 2019 3:35:59 GMT -5
I can see this is really frustrating for you. If it was my scooter, I think with all the problems, I would just put a new head on. New head and piston should not be too much money.
Post by Zino on Nov 7, 2019 7:33:54 GMT -5
That is how I got the Malossi on the Wife's Vino ,I snapped a exhaust bolt off. I figured I had as much time in effort in the the ezout fix crawling around on the floor . I might as well just put some go fast parts on.
So I put a new cylinder on and of course I have to inform my wife this stock pipe is kinda old I should just take care of that .
Post by Zino on Nov 7, 2019 7:57:31 GMT -5
@ Zino18 ….. your awesome !lol Anyway here is picture of the exhaust port looks pretty good ( this was taken last week before I snapped the stud ), but how could I take measurements to see if port is so called warped ? In the picture the upper exhaust manifold does not look like it goes around the bolt is that sheared off . It probalbly is just a shadow your shroud is melted and you have alot of blowby spooge on the right of the picture this problem definetly has been going on awhile
love2ride1111
Post by love2ride1111 on Nov 7, 2019 9:49:54 GMT -5
@zino18
I don't understand , could you say it in a different way ?
Are you saying you think you see the actually manifold has come undone or something ?
Thanks.
love2ride1111
Post by love2ride1111 on Nov 7, 2019 10:23:46 GMT -5
aeroxbud. You wrote : I would just put a new head on. New head and piston should not be too much money. Im not sure if I have the correct tools , time or money to do that right now. I am some what mechanically inclined though have never taken a scooter engine apart before, I have the fear I wouldn't do some spec right and ruin it but I would love to actually in the future.
love2ride1111
Post by love2ride1111 on Nov 7, 2019 14:25:24 GMT -5
Apparently it appears I have to helicoil the one side of exhaust port. I went out under there with ratchet and there again I could tighten it. So I don't have any experience with helicoils. Do I have to drill , if so I don't think I would be able to drill a straight hole ?
Post by aeroxbud on Nov 7, 2019 15:31:08 GMT -5
You already have the hole. So the drill should follow it. Lots of how to fit helicoils on YouTube
love2ride1111
Post by love2ride1111 on Nov 7, 2019 16:11:52 GMT -5
Now since I posted that I took everything off and just tighten the bolts and heck they ain't movin' no mater how hard I ratchet. Damn gremlins
love2ride1111
Post by love2ride1111 on Nov 7, 2019 16:35:33 GMT -5
Just tried with small o ring gasket that people keep sending me. Sounds like no muffler at all on.
Post by Zino on Nov 7, 2019 17:35:09 GMT -5
Heli coil really is not that hard on you tube they give examples I would give a level of difficulty somewhat above a oil and filter change and below swapping disc brakes on a car.
As Far as a cylinder swap My 11 year old son has helped me with the last 3 . I would put it around the difficulty of a disc brake job .
Torque wench is a must for head bolts and feeler gauges for measuring ring end gaps . Some screw drivers ,socket wrench,needle nose pliers for wrist pin clips ,rags ,carb cleaner is about 95% of the tools and stuff that you would use I also use copper gasket spray on the head and base gaskets .
Some patience and alot of picture taking as you disassemble .
I taught my son a few new swear words putting in the last wrist pin clip on the floor on one of our builds . The first one I did the easy way at my bench .
Brent has a pretty good tutorial on cylinder swaps with that and the kymco service manual it can be done .
Once you Go 70 cc you will wish you would have went there sooner .
love2ride1111
Post by love2ride1111 on Nov 8, 2019 23:55:05 GMT -5
Can anyone tell me where I can order asap a Tecnigas pipe for my Kymco Cobra in the states online ? I want to replace this which is the Tecnigas R or Next R or something like that.
Post by Zino on Nov 9, 2019 18:53:19 GMT -5
love2ride1111
Post by love2ride1111 on Nov 9, 2019 20:12:21 GMT -5
What does this Reverse exhaust do for our 2 stroke scoots ? Is it louder or quieter ?
Post by aeroxbud on Nov 9, 2019 21:21:03 GMT -5
Apparently it's one of the quietest exhausts. It's Giannelli's top exhaust, so should be a reasonable performer.
love2ride1111
Post by love2ride1111 on Nov 9, 2019 21:25:49 GMT -5
Ok, thank you.
If you are able to, could you go over to my Thread on exhaust leak and rate my spark plug that is showing hot ?
