rings
Sept 17, 2011 21:37:45 GMT -5
Post by teddy554 on Sept 17, 2011 21:37:45 GMT -5
these are the ring i dont know which is the top ring no marking as to top ring shinny one says r n
rings
Sept 17, 2011 21:56:51 GMT -5
Post by speedy1125 on Sept 17, 2011 21:56:51 GMT -5
rings
Sept 18, 2011 8:36:11 GMT -5
Post by teddy554 on Sept 18, 2011 8:36:11 GMT -5
thank you
rings
Sept 18, 2011 8:38:34 GMT -5
Post by teddy554 on Sept 18, 2011 8:38:34 GMT -5
can you tell me what this are used and which way the insertfor
rings
Sept 18, 2011 12:51:45 GMT -5
Post by speedy1125 on Sept 18, 2011 12:51:45 GMT -5
those appear to be valve stem guides and seals. thats for a cylinder head rebuild
rings
Sept 19, 2011 9:09:59 GMT -5
Post by teddy554 on Sept 19, 2011 9:09:59 GMT -5
were do they go
rings
Sept 19, 2011 10:53:41 GMT -5
Post by 90GTVert on Sept 19, 2011 10:53:41 GMT -5
They should already be installed on the head. They go where the valve stem comes through the head on top, but would be hard to see unless your valve springs are removed.
rings
Sept 19, 2011 13:55:29 GMT -5
Post by teddy554 on Sept 19, 2011 13:55:29 GMT -5
so i well have to take the valves off the heads i have and install this on them see i order this bbk with heads cylinder and piston and there is no instruction you dont think they are already on the heads they just sent me extras,
rings
Sept 19, 2011 14:25:48 GMT -5
Post by 90GTVert on Sept 19, 2011 14:25:48 GMT -5
I think they are on the heads. It would be very strange for a head to be assembled with the valve springs in place and leave the seals out for the customer to install. I think you just have a set of spares now.
rings
Sept 19, 2011 15:30:08 GMT -5
Post by teddy554 on Sept 19, 2011 15:30:08 GMT -5
yeah you are right thank you for all the help. i got to say all the help i get from 49cc. com and you guys are exellent
