Post by ApeShit70 on Nov 22, 2019 11:18:48 GMT -5
Well it's slow at my work so I decided to build a slip roll to make exhaust pipes for my scooters. I just started today, but I got a piece of 1" steel ( couldn't find a piece of aluminum) And cut out the ends of the slip roll I'm going to make the rollers for the slip roll and then figure out how and where I'm going to drill out the holes for the end pieces To make it work correctly.
Post by aeroxbud on Nov 22, 2019 12:20:46 GMT -5
That's some serious metal
Post by ApeShit70 on Nov 28, 2019 19:17:34 GMT -5
Post by ApeShit70 on Nov 29, 2019 19:40:49 GMT -5
Best thing about this project is I get the materials for free, and I get paid to do it! Can't beat that!
Post by ApeShit70 on Dec 9, 2019 7:18:00 GMT -5
Well I made the rollers a lot longer than I was going to. 16" now. Almost done. Going to see if it will work witjout help from gears.
Post by ApeShit70 on Dec 28, 2019 17:38:23 GMT -5
Post by aeroxbud on Dec 28, 2019 20:00:13 GMT -5
That looks the business. 👍
Post by jackrides on Dec 30, 2019 13:17:12 GMT -5
Look forward to a vid of how you use it!
Post by ApeShit70 on Dec 30, 2019 20:27:00 GMT -5
Well, you put the piece of sheet metal in it, then you crank the handle! There is a roll in the back that is adjustable, so that way you roll a little at a time..over Rollin is a pain to redo. If you want it to look right and be perfectly round. It is still missing the hears so that the top roll will also move when you crank the handle. But that's on its way.
