Post by 90GTVert on Mar 18, 2012 19:20:55 GMT -5
Looks plenty safe. Bad thing about metal is your variator will clang at idle and I'd imagine prob still damage the guides on the vari itself.
Post by larry001964 on Mar 18, 2012 21:41:40 GMT -5
Looks plenty safe. Bad thing about metal is your variator will clang at idle and I'd imagine prob still damage the guides on the vari itself. I think your right about making them out of a metal, I can keep buying them or i can build new ones out of a better grade plastic that will take the punishment better... thinking now of something along the lines of a plastic used on craftsman screwdriver or a poly urethane hammer.. Still researching plastics
Post by larry001964 on Mar 18, 2012 22:08:56 GMT -5
I can be so stupid at time's, LOL I know the plastic material and where to get it....... The Plastic used in the industrial cutting boards at work, I work in a slaughter house, this stuff is very very tough I can get some tomorrow and begin fabricating new ones from that, you can't break that stuff with a hammer.... Arrrrg of course...
Post by Deleted on Mar 18, 2012 22:26:32 GMT -5
yes! awesome idea
Post by larry001964 on Mar 18, 2012 22:37:49 GMT -5
This works 1Fast I promise Ill make you a set, to save your variator... Kinda sucks having the only 139 stroker on the road LOL..
Post by larry001964 on Mar 25, 2012 18:26:29 GMT -5
Still have a little more work to do on the guide keys but here's the pics I promised.. Hope they work, I made them heavier and thicker than stock as well..
Post by Deleted on Mar 25, 2012 18:56:40 GMT -5
those should last forever and i want some lol
Post by Enviromoto on Mar 25, 2012 19:54:16 GMT -5
Nice. Must have been a pain to cut.
Post by larry001964 on Mar 25, 2012 20:10:49 GMT -5
Nice. Must have been a pain to cut. LOL they were, that's some tough plastic, but Dremel's do help a lot. Think Ill make a jig next so i can make more a lot easily, and I promised Fast a set.
Post by 90GTVert on Mar 25, 2012 21:03:13 GMT -5
Great job!
Post by larry001964 on Mar 26, 2012 10:19:48 GMT -5
Well just an update, The Key guides seem to work, took it out for a short run, now let's see how well they hold up or if i need to find a different material... Wish me luck
Post by Deleted on Mar 26, 2012 19:20:24 GMT -5
let us know how it goes
Post by Deleted on Apr 1, 2012 21:48:02 GMT -5
How are they holding up?
Post by larry001964 on Apr 1, 2012 22:30:11 GMT -5
Hi Fast, so far so good... but I really have not driven it as much this week as I wanted to.. knoticed a small wobble in my front end, turned out to be a bent rim, I'm guessing I did that when I layed it down. Soo that opened up a new mod project, Since my brakes were under powered for the speeds I'm getting I decided to go with a 12" front rim and new tire ( Pirelli again ), also putting a master cylinder and caliper from a 150 hansom boy on it.. I'm also looking for a couple small radiators and a small mechanically driven external oil pump for the cooling system.. The plan is to use the bikes front end air resistance to ram the air thru the radiators, thru the ducting that will be installed behind the radiators, and into the front of the CVT and out the back of the CVT and it's venting.. The oil pump will run off the shroud cooling fan... Any way that's the plan and what I'm building to solve the heat problems both oil and CVT at the same time..
Post by Deleted on Apr 2, 2012 11:11:36 GMT -5
i saw a ram air cvt cooling setup once and it should be effective..cant see how it wouldn't be.
