Post by darius823 on Dec 29, 2019 13:00:03 GMT -5
Would 12-inch wheels fit a scooter that has a 10-inch wheel
Post by milly on Dec 30, 2019 5:59:29 GMT -5
The short case with the 10" does not you usually need the long case engine for 12". Should find links in the video section that Brent does.
Post by 90GTVert on Jan 5, 2020 15:36:30 GMT -5
You may be able to use very low profile tires and make a 12" wheel work on a short case. If it's a long case that had a 10" wheel with a tall tire, then most common 12" wheels will probably work. Be aware of wheel width too. That can cause a problem and some of the 12" wheels are wider than what many scoots with 10" wheels can easily fit.
Post by SMALL CC TEK on Jan 5, 2020 21:50:15 GMT -5
Yep you can use some super short tires on some cases just depends .
