neogie
Post by neogie on Feb 12, 2020 0:34:20 GMT -5
Got the time to try and fix the choke today. However, something weird happen when i used the flip lever pictured above. I’m just confused why scoot idles witht he lever off and it dies the moment i flip it open. Like it does the opposite hahaha
Post by christopher on Feb 12, 2020 7:21:03 GMT -5
If it is already idling without the enrichment circuit and you turn it on it is getting to much fuel and dies. Only needs to be on when first starting most of the time. Mine only needs it for the first 2 or 3 seconds at most. If I accidentally leave it on it will start to cough sputter etc.
Post by Zino on Feb 12, 2020 8:41:13 GMT -5
A trick we always use with a manual choke/enricher when tuning. Run down the road in different throttle positions and at idle . If it runs better with the choke on we need to go up a jet or 2 on that circuit . So conversely if jetted right it should run like crap with the choke/enricher on because you are flooding it.
Post by freeqsee on Feb 18, 2020 4:03:44 GMT -5
How much to keep the manual choke on to let engine warm up?
Post by Zino on Feb 18, 2020 19:27:00 GMT -5
Unless its cold outside you can flip it off right after it starts.
