Post by dandanman232 on Feb 29, 2020 16:56:33 GMT -5
Hey guys I’m new to this forum and really need some help . This is my first 2t scooter I’m trying to fix I have put a 70kit on it a new Cdi new carb everything and new spark plug as well as starter everything is new except the stator and it will turn over and has spark but will not fire I have compression and idk what to do. I’m so use to gy6 it’s got me puzzled could it be the stator not putn our enough spark or what please help me guys and it’s kinda hard to find parts bc not many of them were sold here
Post by Zino on Feb 29, 2020 18:32:19 GMT -5
Welcome to the forums Where are you located ? In the states pgo big max is rebadged as genuine scooters roughhouse or rattler models . Minarelli parts are pretty easy to come buy a ton of universal parts and aftermarket options. What carb did you put on and what 70cc kit ? Is fuel getting to the cylinder ? Here is a copy of the service manual for you www.motorscooterguide.net/Manuals/PGO_PM50_PM110_Service_Manual.pdf
Post by dandanman232 on Mar 19, 2020 16:46:40 GMT -5
I have spark and compression and have changed everything except the damn seals and don’t have a leak tester I just put a new stair on it so I know it should be firing right but even spraying starting fluid nothing
Post by 2stroked on Mar 19, 2020 17:41:28 GMT -5
Ya got spark. Ya got fuel. Ya got compression. So, what's left? Timing. The cdi might be wrong. Could have the wrong baseline curve, or the flywheel/stator could.be off from each other. Line up the timing marks and see where your piston is...
Post by dandanman232 on Mar 23, 2020 14:13:59 GMT -5
Ok so how is the piston supposed to be compared to the flywheel bc I don’t see how to change anything bc it has a key way that it just fits into
Post by geoffh on Mar 23, 2020 15:24:47 GMT -5
I would suggest you take a step back,fit the old cdi,old carb and see if there is life there,a lot of 50cc carbs need up jetting to suit a 70 set up.check the case is not flooded, access the reed valve to do this,check the arrow on the piston is pointing to the exhaust port.you will have to have the air box attached and the cowls all in place before you try to start it.? did it ever run.
Post by dandanman232 on Mar 27, 2020 18:53:14 GMT -5
It never ran no so I’m stumped but I know the piston is in the right direction I took my time when I put everything back together
Post by 2stroked on Mar 31, 2020 14:42:51 GMT -5
Ok so how is the piston supposed to be compared to the flywheel bc I don’t see how to change anything bc it has a key way that it just fits into While this is true for most scoots, the fluwheels arent all keyed the same way....
Post by dandanman232 on Apr 8, 2020 23:05:35 GMT -5
I took it completely apart and found the seal in the cvt on the crank had come out some how, well I messed up and stripped the bolts that hold the reads in place and my drill bits and tap set are just getn in my nerves so I’m taking it to the machine shop that’s on my road and get new bolts in it and then going to put everything back together and hope it runs,
