Post by hilltopper2 on Sept 27, 2011 21:38:00 GMT -5
When I start my scooter sometimes when I try to give it some gas it just bogs down and tries to die. If I keep trying it will finally take of and run. I have cleaned the carb twice. The choked works and I believe the air fuel adjustment is right. Anybody have any ideals.
Post by speedy1125 on Sept 27, 2011 21:57:40 GMT -5
sounds way lean. what does the plug look like? what are the valves set on?
Post by hilltopper2 on Sept 28, 2011 19:43:04 GMT -5
I haven't checked, what color should it be?
Post by speedy1125 on Sept 28, 2011 23:33:36 GMT -5
Post by nhraracer on Sept 30, 2011 15:07:38 GMT -5
I have the same problem,but my electric choke is not working. Its a stock 2005 zuma 49cc teikei carbuator, with electric choke. I cant find one under $ 140.00 bucks. My question is will the dellorto 14 mm choke work,its $41 bucks. $140 IS ECECTRIC choke only, tks
Post by 90GTVert on Oct 1, 2011 7:44:33 GMT -5
Welcome NHRARacer! I haven't messed with a Yamaha carb, so I'm not really sure what works. I know they use a different throttle setup than the Chinese stuff I'm used to. If the rest is pretty much the same though, maybe a typical Chinese enricher will work? There's one for $10 about 1/3 way down this page. www.scrappydogscooters.com/COMMON_PARTS.htmlIf it looks like that, it could be worth trying for $10 if no one else can give you a better answer.
Post by nhraracer on Oct 1, 2011 14:30:45 GMT -5
Thanks ordered one and will post if it works or not.
Post by ososlow on Oct 1, 2011 16:14:04 GMT -5
if it only happens right after you start it up, its probably cus the choke and enricher are both activated so your already running way rich then you give it some gas which makes it waaaay to rich and it bogs down. my beater is the same way. if it happens randomly hot or cold then it probably is the enricher
Post by nhraracer on Oct 5, 2011 16:46:19 GMT -5
THE one i ordered did not work,to large,would not go into the carbuator.
Post by nhraracer on Oct 5, 2011 16:49:56 GMT -5
I can pull the electric choke out, pull a little gas in and it starts right up. It even idles down,long as i keep my finger over the hole,runs fine. Has full throttle and runs fine,till i remove my finger. Any help will be very greatfull, from all i can fine,its cheaper to replace the carbuator.
