Post by 49ccsofdestruction on Oct 2, 2011 20:25:06 GMT -5
i read the carb adjust procedure in the tech section and there are questions. my carb has a mixture screw but no idle screw. the only adjustment on the throttle cable is for taking up the slack just like the one at the hand throttle. i put the scoot on the stand and if i turn the mix screw for highest rpm the rear wheel spins really fast. the only option i have is to turn screw until wheel stops. scoot sounds good, not running rich and it accelerates fine. am i missing the idle adjustmeent or does ny carb not have one.
Post by jmkjr72 on Oct 2, 2011 20:33:11 GMT -5
you have to be missing an adjustment somewhere i have never seen a carb where you couldnt set the idle new carbs you can adjust the idle but the air/fuel screw is hidden
Post by 90GTVert on Oct 2, 2011 20:38:03 GMT -5
I haven't seen one without an idle speed adjustment.
Post by 49ccsofdestruction on Oct 2, 2011 21:38:36 GMT -5
hmmmkay! maybe the screw i'm turnin IS the idle screw and i need to find the mix screw. i'll look 2morrow and let ya know. thanx fer da help!
Post by 49ccsofdestruction on Oct 3, 2011 15:57:33 GMT -5
yup that was the idle screw and the mix screw was right next to it just like in the pic. yeah im an idiot! thanx!
