Post by sidsgirl on Oct 3, 2011 12:42:01 GMT -5
I recently lost my keys in the lake and had to start off by ordering a new ignition switch, so I changed that out - scooter turns over n over wont start - then i order and replace the CDI and Ignition coil and spark plug- still turns over n over and wont start. Does this tao tao have a computer or something that needs to be reset because i changed out the ignition? I cant figure out y in the world it wont start. Thanks
Post by Fox on Oct 3, 2011 13:00:25 GMT -5
How long did it sit after you lost the keys til you replaced the ignition?
Post by sidsgirl on Oct 3, 2011 13:03:26 GMT -5
Awh 30 to 45 days - I just cant figure out WHY it wont start, just spins over n over. I keep spending $ to replace parts with no results. Thanks
Post by 90GTVert on Oct 3, 2011 13:57:30 GMT -5
Post by speedy1125 on Oct 3, 2011 14:21:12 GMT -5
check the vacuum line that goes from the intake to the fuel valve for cracks, and the intake itself. Yesterday, a customer had a bike with the vac. port that fell off in my hand and the hose to the fuel valve was wasted. it was sucking in so much unmetered air that it would not run.
You should have checked spark before replacing parts but you need to verify it now anyway, do you know how to do this?
Once you verify spark and check/repair any obvious vacuum leaks we can further advise you.
Post by Fox on Oct 3, 2011 15:12:01 GMT -5
I betcha $5 the carburetor is gummed up. Go buy a can of caruretor spray cleaner for a few dollars at the auto parts. Take the carb off, turn it upside down and remove the bottom bowl. Then remove the jets and spray the crap out of every single hole in the entire carb body. Even the ones you think don't matter. Spray 'em all real good. Then make sure the jets are clear by spraying spray in one end. Spray should come out the other end. The idle jet (aka pilot jet)has a super tiny hole in it. If you can't blow air through it then it's clogged and the scoot won't run.
This kid pretty much covers it. Your carb will be slightly different.
FFWD> to 5:00
Post by sidsgirl on Oct 30, 2011 15:21:45 GMT -5
Ive checked it all and still wont start there is no spark to the plug any more suggestions? Thanks
Post by speedy1125 on Oct 30, 2011 16:06:53 GMT -5
Does this tao tao have a computer or something that needs to be reset because i changed out the ignition? I cant figure out y in the world it wont start. Thanks no computer like that no. is the engine kill switch on the right handlebar set to run or kill? if its set to kill there will be no spark.
