Post by rehabkymco on Jun 12, 2020 13:28:29 GMT -5
Well the Kymco needs a variator. And I'm trying to get the best performance I can and the cheap eBay(DLH) did a good job as a replacement but not sure if it actually did anything for performance. And if one that you may use is better then please comment below
Post by tortoise2 on Jun 12, 2020 13:43:57 GMT -5
trying to get the best performance For 50cc . . stock variator with 5 gram sliders.
Post by rehabkymco on Jun 12, 2020 17:47:09 GMT -5
trying to get the best performance For 50cc . . stock variator with 5 gram sliders. It's a 72cc, ported stock head, A9 cam, aftermarket pipe, and has 17/49 upgear kit. And what i have is basically a stock replacement
Petro
Post by Petro on Jul 4, 2020 1:12:20 GMT -5
I got the Naraku RS racing, other than that it's reving more with the same weights compared to stock I dont see any advantages... It is way lighter but that's nothing I notice riding the scooter.
Mind You, I never been deep into the CVT in the first place since I always got the performance I wanted with the stock parts, which is around 40 mph low revs cruising. I am playing around with it a bit now since I am locked up in Sweden (No lock up/quarantine here despite heavy Corona so Europe doesn't accept us and I travel Europe in the summer with my scooter) but I must say, a good engine tuning and the stock works flawlessly and reliable.
I am not voting since the Naraku HS revs more which I don't like. However, this is probably what most people want from a performance part so the kit does what it's claiming. I however goes stock with the Naraku with me as spare parts.
Post by Zino on Jul 4, 2020 7:21:16 GMT -5
I goot a go italian I like and have used both the POlini and Multi Var. Polini is cheaper most places so there is my tie breaker
Post by Steve B on Aug 17, 2020 12:05:29 GMT -5
Malossi multivar is a top contender.
Post by aeroxbud on Aug 17, 2020 19:10:40 GMT -5
I have never used the Naraku variator. In my experience the Malossi multivar is the best. Then the Polini variator, then the Hi speed Polini. The hi speed is a cheaper and not as good version of their original variator. Any would be better than stock. I have found I sometimes have to alter weights slightly for different brands.
Post by Deleted on Aug 17, 2020 19:24:55 GMT -5
It's a 72cc, ported stock head, A9 cam, aftermarket pipe, and has 17/49 upgear kit. And what i have is basically a stock replacement That 17/49 upgear kit gave me some crazy 9:1 ratio. Even 88cc with bigger valves and good compression couldn't handle that.
Post by rehabkymco on Aug 18, 2020 4:54:51 GMT -5
Thanks everybody. I ended up getting the Sspg performance 89mm which is real close to the Naraku HS.
Post by rehabkymco on Aug 18, 2020 4:59:14 GMT -5
It's a 72cc, ported stock head, A9 cam, aftermarket pipe, and has 17/49 upgear kit. And what i have is basically a stock replacement That 17/49 upgear kit gave me some crazy 9:1 ratio. Even 88cc with bigger valves and good compression couldn't handle that. In my Kymco cases with 15t clutch shaft (gives 10:1) I was hitting 55mph+ with a 72cc. And had plenty of torque to handle it. Current setup is with 16t clutch for 9.367 Final. These 4t can push a lot more then most give them credit.
Post by scooter7878 on Aug 30, 2021 23:18:58 GMT -5
Well the Kymco needs a variator. And I'm trying to get the best performance I can and the cheap eBay(DLH) did a good job as a replacement but not sure if it actually did anything for performance. And if one that you may use is better then please comment below . The naraku h/s racing variator is the best one I have used I haven't tried a polini or malossi but I can say the naraku def made a huge improvement in take off and a good bit of top speed. And I've had it for a while now and I beal the living crap out of my scooter and it shows no sign of wear. It's smooth fast and lasts a long time I got almost 9500 rpm top speed and I'm usually running wot 90 percent of the time. My belt rides all way to the top without any modifications. The only issue I been having is bc it's slightly larger when I'm wot the belt rubs in the starter Bendix slightly. I'm still working on a fix for that issue but I believe that will happen with any of the over size variator
