Post by pinkscoot on Jun 22, 2020 19:21:10 GMT -5
I have finally found the problem with my ET$. It looks like I screwed up the CDI connector. I would love to pull the pin and get it right but I have no clue how to get these pins out. I tried finding the tang and its not there. I have found the connector here: www.amazon.com/Kuryakyn-4832-8-Pin-Hardwire-Adapter/dp/B0022ZOOKS but it only has 5 wires connected and I need 7. Here are pictures of my connector: If any one knows how to get these out it would be great.
Post by matlock on Jun 23, 2020 11:15:06 GMT -5
still okking how to remove pin i wonder if they dont just slip out from the front by pushing them into the connector anyways maybe this can help you a bit with proper wiring
Post by pinkscoot on Jun 23, 2020 16:59:32 GMT -5
Looking at the connector I think the connector pops open in some way. I went ahead and ordered the one from Amazon that I'll be able to explore a bit and see what's what.
Post by pinkscoot on Jun 23, 2020 17:05:43 GMT -5
Post by FrankenMech on Jun 23, 2020 18:35:38 GMT -5
Sometimes it takes a magnifying glass and some probing but they always come apart unless they have been potted with urethane or epoxy, usually a military or aerospace process.
Post by matlock on Jun 24, 2020 0:33:32 GMT -5
everytime a problem needs solving you will see
Post by pinkscoot on Jul 4, 2020 14:10:23 GMT -5
My hand was feeling up to working on this and I got the new connector. The problem with it is that it was only 5 wires and no spades for the others. There is definitely a problem with the connector because the scoot will start and run until I lightly touch the connector. It could be the CDI but those pins are all tight. I figured out how to get them out of the new one but the old one is a different story. I managed to find the connector and spades from a manufacturer and have them on order. I'll have the new connector Wednesday and be able to put it together.
Post by snaker on Jul 5, 2020 14:04:52 GMT -5
Be sure to inspect the wire to terminal crimp connections. I've had issues where the wire had been stripped horribly and the terminals were crimped on insulation instead of conductor. A wire can break and only be held together by the insulation. A light pull is a good idea. Look for the insulation doing a hour glass stretch across a break.
The pin to pin to pin contact is a given but make sure the connector is actually locking closed and allowing some slack in the wire harness. I've seen where a too tight wire harness pulls on the pins and gets sketchy.
Post by pinkscoot on Jul 13, 2020 18:29:39 GMT -5
Sunday my hand was feeling up too stripping and crimping the new tabs and connector. It suggested I use an Amp crimping tool, I opted for a small pair of needle nose pliers. I was able to get them all crimped and in the connector. The scoot started right up. I took it for a ride and allows good. I rode it to work today and went home the long way. I really missed this scooter. It just handles so well and I always get looks when I'm on it.
Post by FrankenMech on Jul 13, 2020 18:44:42 GMT -5
Using the wrong tool on crimps is a mistake.
Post by aeroxbud on Jul 13, 2020 19:35:59 GMT -5
That pinkscoot, living on the edge!
