cfn
Post by cfn on Oct 5, 2011 16:46:52 GMT -5
What i have is a 05 Triton r4 49cc with a 70cc bbk and performance pipe.Im running a 80 main jet and have not changed the belt or clutch/spring.The sound is coming from the rear of the cover plate.I did a compression test wot and had 105psi.Thanks
Post by 90GTVert on Oct 5, 2011 20:45:58 GMT -5
105psi is not optimal, but it could be a problem with the tester or something and not the first place I'd look since the sound is coming from the rear of the CVT cover. I'd start by pulling the CVT cover and inspecting everything in there. Look for signs of contact or anything else that looks out of place.
cfn
Post by cfn on Oct 6, 2011 18:13:06 GMT -5
Well i found that my belt was cracked in 3 places so i replaced it.Also i have a flat spot on one of the rollers so i had to order new ones.Now should i go with a 5gms what it in there now is 4gms?Thanks.
Post by 90GTVert on Oct 6, 2011 19:35:50 GMT -5
They don't always come with the same weights. The best bet would be to weigh them and then determine what you want based on that. Lighter if you want more revs, heavier if you want less.
cfn
Post by cfn on Oct 9, 2011 13:01:12 GMT -5
Well today i fixed a exhaust leek checked the compression and it was 110psi .After putting the plug back in i ran it only to find it was missing and backfiring.Pulled the plug and found a small peace of what looked like a drop of sundering.Put the plug back in and it is running fine.what should i do now?
Post by 90GTVert on Oct 9, 2011 13:16:30 GMT -5
I'd be inclined to pull the head and get a look in there, maybe even pull the cylinder and check the piston and rings since you've found a piece of something and the compression is on the low side. You say it runs fine though, so it's your call if you feel comfortable trusting it or not. You should be holding the throttle wide open for your compression tests. I also find I can pick up better readings using the kick starter a few times after cranking it over with the e-start.
cfn
Post by cfn on Oct 9, 2011 13:35:50 GMT -5
Thanks im thinking about pulling the head when i change the rollers this week.Looks like ill have a day or 2 with the rain coming.What pipe should i use?Im running one that ive drilled but its i bit loud.
Post by 90GTVert on Oct 9, 2011 14:48:24 GMT -5
You said you have a performance pipe, so I'd probably go with that and rejet if needed... or are you asking about buying something new?
cfn
Post by cfn on Oct 9, 2011 15:38:32 GMT -5
thinking about something new.
Post by 90GTVert on Oct 9, 2011 16:23:09 GMT -5
If you want something pretty quiet, available at a good price, and suitable for a sport kit, you could look into a Leo Vince SP3. The Leo Vince ZX is a good choice that may offer a little more performance but it's a little louder and doesn't look anything like a stock pipe. If you've got more money to spend, the Yasuni pipes get great reviews... probably the Z or R for this app.
Post by 1quikvento on Oct 11, 2011 11:20:06 GMT -5
I dunno what it is exactly but some part of my variator clicks and clanks quite often. Ive inspected it numerous times and cant find signs of wear, so i just live it. Plus my triton was "knocking" at one point. Irealized it was the belt. There was evidence of this on the upper and lower portion inside my cvt cover where I was able to see the belt scrape thru the rubber dust and hit the cover. Might be a good idea to measure the thickness of yours and order one with your other parts. Cuz eventually,since it is a part that wears, you will need one.
Oh yeah, u already replaced it. So is it still making noise?
And welcome to the site! Im just a small distance from you in Myrtle Beach,SC. Im hoping to find some news sometime about scooter races here in our area. That would be hella fun.
cfn
Post by cfn on Oct 12, 2011 17:59:36 GMT -5
Replaced the rollers today and replace the main jet with 115 it will only run with the air box off.Now do i need to go with a after market air filter or what?
Post by ososlow on Oct 12, 2011 18:28:07 GMT -5
i would say your running way too rich now. 80 to 115 is a rather large jump did you get any jets between those? hows your idle? when you had the 80 mj was it backfiring from the carb or the muffler?
Post by 1quikvento on Oct 12, 2011 20:17:22 GMT -5
I agree. 115 too big. You said at one point after a plug change and with the 80 it was running fine- so why the jump all the way to 115?
Id suggest to keep the factory airbox. The minimal gain that u may achieve doesnt quite make up for the extra noise. Ask anyone on this site too and you'll find that your scooter will be much easier to tune properly with the stock air box.
cfn
Post by cfn on Oct 18, 2011 10:36:03 GMT -5
RIP My Triton kicked the bering...................That knocking sound i was hearing was it.Now im thinking about replacing it with a new 90cc .Ive found a 90cc that will bolt in place.Now will i need to order a new Carband pipe?
