Flooding
Jun 25, 2020 14:11:16 GMT -5
via mobile
Post by lokisupra on Jun 25, 2020 14:11:16 GMT -5
Have a 50cc icebear that keeps flooding the carb to the point it is running out through the air filter while running. Have had 2 separate carbs on this scooter and still the same issue. Has a manual petcock and a vacumme operated pulse pump for fuel delivery, is it possible the pulse pump could be too high volume if it is for a 150cc not a 50cc? I bought second hand and know it was replaced but not if they used the same part# part.
Post by tortoise2 on Jun 25, 2020 14:40:13 GMT -5
50cc icebear . . vacumme operated pulse pump Maddog model with floor level gas tank?
Post by FrankenMech on Jun 25, 2020 15:37:34 GMT -5
Manual petcock AND a vacuum pump, -WHY?
Debris in fuel system without adequate filtration. Debris in float needle.
Improper fuel line routing.
