Post by sking3111 on Oct 7, 2011 22:07:32 GMT -5
I am in the procese of putting a 47mm big bore kit on my eton beamer ,can any one tell me if i will have to go up a spark plug size?i have a ngk br7h7 now thanks for any help! o have # 90 jet in will that work good with the kit?
Post by 90GTVert on Oct 7, 2011 22:12:21 GMT -5
The spark plug size shouldn't change. Most use BR8HS or BR7HS. 90 is a good size main, but if that's what works best on the 50 it's pretty likely you'll need to go a little larger.
Post by jmkjr72 on Oct 8, 2011 11:23:09 GMT -5
for the zumas we run either an br8hs or br9hs now if you are running a polini or other long reach head you will need es plugs the liquid cooled kits also run es plugs
