hvacjay
Working on house chores and cleaning up my gy6 50cc engine case
Post by hvacjay on Jul 7, 2020 19:22:57 GMT -5
Post by FrankenMech on Jul 7, 2020 21:53:20 GMT -5
These little scoots are made to be electric start only. The kickstart is there for emergencies. It might be easier to just buy a new 50cc or even a 150cc engine since you can weld and install it.
There should be a VIN plate on the frame and the VIN is stamped on the frame also. I hope you didn't give much for it. Did he have a valid title? That is an important part. We have a VIN number lookup for stolen scoots here also. You will need a clean title to register it.
RIDE NAKED!
Throw the plastics in the trash. They are a PITA to fool with every time you need to make an adjustment or fix anything.
PDub
Ann Arbor MEEEEEchigan
Post by PDub on Jul 7, 2020 22:35:05 GMT -5
I sure hope you didn't pay anything for that!!
hvacjay
Post by hvacjay on Jul 9, 2020 13:01:57 GMT -5
From what I've read and researched about it the 150cc engine is a direct bolt on to the 50cc bike frame correct?
hvacjay
Post by hvacjay on Jul 9, 2020 13:03:30 GMT -5
And no I didn't pay a dime for the scooter. Surprisingly the frames in really great shape just a few little areas of minor surface rust the handlebars are nice and straight too.the triple tree looks nice and straight at the very least I've got a solid frame to work with
Post by FrankenMech on Jul 9, 2020 15:14:13 GMT -5
From what I've read and researched about it the 150cc engine is a direct bolt on to the 50cc bike frame correct? NO, the mounts are different, 50cc is a bottom mount engine. A 150cc is a top mount engine. Different frame mount points are used. check out some pictures of frames and engines. Since you can weld you may be able to fabricate some mounts.
hvacjay
Post by hvacjay on Jul 10, 2020 1:40:51 GMT -5
Thank you for the information on the frame mounts. And on a side note, that first TaoTao 50cc white scooter that I've been working on of my neighbors I actually had that thing going 50 miles per hour provided the speedometers accurate.
Post by FrankenMech on Jul 10, 2020 10:57:25 GMT -5
Chinese speedometers accurate.... ROFLMAO
