Post by ninja4ever65 on Oct 8, 2011 10:02:30 GMT -5
Need helps fast ! i have a Aprilia Factory -07 thats starts but want run because when you give more gas on the throttle it dies because the fuel injection dont give any fuel !? i have change the fuel pump and the reeds and have good compression and also clean the injection in a cleaner so whats next
Post by 90GTVert on Oct 8, 2011 10:59:48 GMT -5
Welcome to the forum. I'm not real familiar with the FI scoots, but hopefully someone else here can help. My only suggestions would be the obvious stuff first like check the fuel lines, inline fuel filter, in tank fuel filter if equipped, and try with the fuel cap off (venting).
Post by speedy1125 on Oct 8, 2011 12:03:18 GMT -5
Post by ososlow on Oct 8, 2011 12:03:44 GMT -5
i would check for a leaky intake gasket, bad/ mis adjusted tps, bad map sensor, and a nicked/torn or dry rotted o ring around the injector. along with what vert suggested
