Post by mobdarrell on Jul 11, 2020 2:21:05 GMT -5
Just a quick tip for anyone who runs into this problem. The small bulb for the high beam indicator on the speedo can burn out and leave the circuit grounded. This will burn out your headlight.
Also if you need a headlight ask the guys at O'Reilly's. My local store has them behind the counter for about $2.50. Buy a few spares while you're there.
Post by GrumpyUnk on Jul 11, 2020 7:51:31 GMT -5
Another cause of headlight burn out is a failing voltage regulator. The voltage generated rises as the rpms increase. If not limited, the voltage could get so high it caused filament failure. I never even thought to ask as O'Reilly's. tom
