Post by FrankenMech on Jul 20, 2020 12:36:49 GMT -5
Get a new headlight while you can also.
Post by FrankenMech on Jul 20, 2020 12:37:48 GMT -5
And a new tail light.
Post by FrankenMech on Jul 20, 2020 12:38:54 GMT -5
And while you are guessing a new set of handle bars from a big wheel.
Post by Mech Warrior on Jul 20, 2020 12:40:46 GMT -5
And blinkers.
Post by tortoise2 on Jul 20, 2020 15:49:16 GMT -5
Speculating the gremlin MAY be fuel supply related . . insufficient refilling of the carb bowl? It appears the only fuel reaching the throttle bore is via acceleration pump squirts. Might try twisting up the carb bowl vent hose and squirting in some additional gas or brake/carb cleaner.
Post by Mech Warrior on Jul 20, 2020 19:09:04 GMT -5
You had the exact same issue before you switched the carburetor?
Post by Mech Warrior on Jul 20, 2020 19:14:18 GMT -5
My next question is the intake manifold on tight? Is there anything stuck underneath it keeping it from properly seating , Its hard to tell from photo but it looks like something is stuck under it up by the head or is that just strangely cut?
Post by dennisoates on Jul 22, 2020 7:37:05 GMT -5
solved, vacuum leak at manifold. new o ring installed.
Post by dennisoates on Jul 22, 2020 7:39:48 GMT -5
To accurately diagnose problems follow the troubleshooting guide in the service manual to the letter. Guessing and shotgunning a scoot with new parts is not the way to fix them.
On the other hand, have you checked and adjusted the rear brake?
Post by dennisoates on Jul 22, 2020 7:40:22 GMT -5
vacuum leak at manifold, shotgunning finally worked, love the new horn too.
Post by tortoise2 on Jul 22, 2020 12:09:32 GMT -5
solved, vacuum leak at manifold. new o ring installed. EXCELLENT troubleshooting to find the gremlin!
