Post by dude on Oct 11, 2011 18:02:10 GMT -5
I am having idling trouble with BB 2stk stock up jetted carb. It has over 2000 miles and its just a little rich. It started when I ran it hard then came to a stop at a stop light. It would idle fast then you hit the gas once and it would idle. I have ran sea foam in it a few times. Changed the chock no cables binding. But is getting worse even now at slow speeds. I shut the key off once at high idle and it stayed running. I am running a BPR7HS and squish is 1.2. Any ideals??
Post by 90GTVert on Oct 11, 2011 21:08:21 GMT -5
Checked for intake leaks? Also, if it's running lean or hot for whatever reason it might idle high after WOT.
Post by Enviromoto on Oct 12, 2011 8:37:49 GMT -5
Do a pressure test.
Post by dude on Oct 14, 2011 21:35:58 GMT -5
Pressure test good, Tried 1 step colder plug, 1 clip leaner on neddle jet. Still need to reset air mixture and idle.
