Post by bigkahuna427 on Oct 12, 2011 11:31:20 GMT -5
I came to this forum and introduce myself with a thread titled “So this is my challenge”. The challenge continues with these two really cheap chinese scooters. They were really a mess had been sitting outside in the Florida sun and looked to have fallen over plenty with lots of busted up plastics. These scooters are 2003 Geely scooters. They have a vertical jug carb on front and exhaust at rear of the jug. They have a bathed in oil chain drive transmission. From what I have been told these are not worth my time. I went ahead stripped them down to the frame went right through them with one now complete and running and the other still needing a couple of things. My post today is to simply document what I did in hopes it may be of help to someone in the future.
So here is my challenge. I have two scooters with less than 300 miles on them but they are beat. I am on an island 1500 miles from home and have a small suitcase of tools. I have a Home Depot, Wal Mart and Auto Zone 20 mins. away. My plan is to make one out of two using one of these as a donor scooter.
I strip down the first one degrease and clean everything then paint the frame and motor.
I reassemble the frame install the motor, wiring harness, mask and re-paint wheels. I had to cure several issues with the wiring harness mostly due to crumbling broken cheap plastic connectors. I always use solder and shrink tubing with wiring repairs for reliability. Replaced all the fuel and vacum lines and cleaned out the carb. At this point I am focusing on functionality so to the donor scooter I go. I rob a coil and the hand controls which were all busted up, the missing choke plunger and not much else. Both gas tanks I have are pretty rusty so I take the oil injection tank from the donor and bungee cord it to the frame.
A couple of kicks and it runs! I adjust the carb and ride it up and down the dirt road a few times. From there this bike has always started one kick no choke (temp in the high 80s here) and I do not even have to give it gas. It just starts and maintains an idle!
So with this one running and not much taken from the other one the gears in my head are turning. I did a search in the local Craigslist and find a parts scooter a half hour south of Sanibel in Bonita He just so happens to have a Geely parts scooter that he has robbed all the parts he needs. He wants $100 but I negotiated a fair price of $60. I go back the next day with tools and strip everything off of it leaving the frame so I can fit it all in the trunk of a Honda Accord. The odometer on this one reads 61 miles. I guess these things were so bad people gave up on them pretty quickly. Now I have an extra engine, carb, hand controls in perfect condition and a few body parts that will save me uber amounts of time. I also have another gas tank but this one is rusty too.
So on to scooter number two. I basically do the same process as scooter 1. However, I was not able to get it running with compression, fuel and spark all seemingly ok. I then start swapping parts plugs, carbs, coils and even the motor thinking maybe the stator timing is somehow wrong or maybe the compression isn't enough or I am pushing pressure to the crankcase. I was only able to get the engine up to maybe 1500 RPMs and no throttle response. I am no dummy but am a little baffled at this point. I do not have a compression tester here but there was evidence of water in the cylinder. Took the top end off the original engine and found a little rust around the very top of the cylinder bore. This was about 3/8” from the top and cleaned up quick with just a few scuffs of sandpaper. I think my next plan of attack is to show up with a new carb (maybe) and rings and take another shot at it.
s1012.photobucket.com/albums/af248/nwsmith427/Geely%20Scooter%20Stuff/
