Post by scooter Bill on Oct 12, 2011 18:21:14 GMT -5
hello all, i have a dilema my 50cc trike keeps dying i have changed carb, cdi and coil this thing will run for mile or 2 then dies as if its running out of gas i turn the ignigtion off back on it will start right up and take off again for another couple miles then die and repeat, this is getting old could this be a stator problem all input is appreciated
Post by 90GTVert on Oct 12, 2011 19:34:27 GMT -5
:welcome:
Do you have an alarm/remote start on your trike? I think some of those will only run for a certain amount of time if you start it with remote start. Might work like that in other cases?
Post by scooter Bill on Oct 12, 2011 19:53:47 GMT -5
no remote start no alarm it just looses power like its running outta gas but once i shut it off it starts right back up i was betting carb or cdi i was wrong read in another thread possibly stator heating up was hoping someone else had experienced this phenomenon
Post by Fox on Oct 12, 2011 20:03:46 GMT -5
Yeah I've seena thread where the stator was bad and it did exactly what yours is doing. Might as well get a new regulator too cause if there's one thing I've learned about these Chinese scoots is that you never know until you know. One time I fixed a scooter that had a bad reg. and stator at the same time. It gave me fits for about a 1/2 an hour and I finally stumbled on the cure. I'm no Genius by any means.
:swear:
Post by speedy1125 on Oct 12, 2011 20:09:48 GMT -5
Im with Fox on this as well, I have seen heat cause some stators and other electronics to do whacky things when hot. If it were me i would go Stator and regulator to start with also.
Post by scooter Bill on Oct 12, 2011 20:16:34 GMT -5
Thanks guys ordered stator earlier will order reg to. how big a job is the stator to change any special tools needed? thanks again
Post by jmkjr72 on Oct 12, 2011 20:21:17 GMT -5
one other thing have you looked at the petcock i personaly would start there and replace it with a manual one
Post by Fox on Oct 12, 2011 20:27:27 GMT -5
Stator requires a $30 impact from Harbor Freight to remove the nut on the flywheel and a 24mmx1mm right hand thread flywheel puller tool. www.harborfreight.com/12-volt-1-2-half-inch-emergency-impact-wrench-92349.html You thread the puller into the flywheel and then hold back on it with a wrench and turn the inner shaft with another wrench or socket and it pulls the flywheel off. Pics below: Sometimes the flywheel is stubborn. In that case DO NOT OVER TIGHTEN THE PULLER! Just build up a good amount of force, and then tap on the end of the puller's inner shaft with a ball peen hammer or a brass hammer. Don't kill it! The vibrations will sometimes break the thing free. You don't want to damage the threads on the crankshaft.
Post by scooter Bill on Oct 12, 2011 20:36:55 GMT -5
Thanks for all the info have hub puller that should work and impact. I'm new and this is by far the best website i've ever seen you guys rock.
